Datalogging WGDC and boost leaks
06-04-2012, 11:00 AM | #1 |
70
Rep 2,197
Hey guys, I'm working on a data logging DIY and I need some help. If anyone has a data log of of their WGDCs when they had a boost leak I would greatly appreciate it if you would email me the CSV file( allenrader1@Gmail.com )
Sorry to interrupt the "what intake/exhaust/FMIC/rasp free exhaust should I order?" thread pattern. |
06-04-2012, 11:07 AM | #2 |
87
Rep 2,854
quickest and best solution would to be to just send them over to terry. if he says everything is ok, you'll then have your own baseline to work from if future problems arise.
06-04-2012, 11:12 AM | #3 |
70
Rep 2,197
No, i don't have a boost leak and never have. That's the problem. I need logs from a couple people of their WGDCs when they had a boost leak so I can incorporate it into a DIY on data logging and data interpretation.
06-04-2012, 11:12 AM | #4 |
161
Rep 7,377
If pwm maxes out straight away you got a leak.
06-04-2012, 11:17 AM | #5 |
87
Rep 2,854
ah i see what you mean. i read your first post too fast
06-04-2012, 11:29 AM | #7 |
Team Zissou
3065
Rep 10,197
rader, here are a couple datalogs when I was diagnosing my boost leak. along with WGDC i have boost set point vs. actual boost... and if you want any more info the boost leak was where the charge pipe meets up to the intake manifold.
