what ever happened to the fuel pump upgrades ?
06-02-2012, 09:57 AM | #1 |
142
Rep 2,661
??? where all the problems solved with a flash?
06-02-2012, 01:39 PM | #4 |
13
Rep 156
Drives: Please delete my account
06-02-2012, 01:55 PM | #5 |
130
Rep 5,040
folks with upgraded turbos are already using Cobb alongside piggybacks because of its fueling advantage - beats modding the hardware IMO....
06-02-2012, 01:56 PM | #6 |
70
Rep 2,197
06-02-2012, 03:42 PM | #7 |
81
Rep 1,142
06-02-2012, 04:23 PM | #8 |
Rep 89
What about the 1M's hp fuel pump? I know that its different than ours...
FBO (with BMW Performance exhaust) E93 335i | RB Turbos | Procede Rev3 | Vishnu Pwm Meth
06-02-2012, 04:27 PM | #9 |
70
Rep 2,197
06-02-2012, 10:29 PM | #11 |
81
Rep 1,142
06-02-2012, 10:40 PM | #12 |
177
Rep 6,631
My understanding is the actual fueling hardware is good for quite a bit more fuel than how the wideband bias approach the piggybacks use, and Cobb is the only one to properly take advantage. They can run 18 psi peak tapering to 16 at redline on 93 octane no meth with RB turbos with 12 AFRs straight across.
While this may not be a proper comparison to say a single turbo with even greater fueling requirements, it does show you there is a proper way to fuel these things and to be honest, a piggyback alone isn't it. While the fueling portion is resolved, there are other issues with bringing this out for public consumption that I am not comfortable getting into. DISCLAIMER: I run a piggyback (JB4 G5) standalone. I can run Map 2 (14.5 psi peak) with CPS enabled on 93 octane with no fuel trim issues or drama. With a TON of meth, it appears I can get away with 20 psi peak without leaning out. Then again, I have RBs, not a single turbo.
E90 LCI N54 6AT
06-02-2012, 10:49 PM | #13 |
70
Rep 2,197
06-02-2012, 11:13 PM | #14 |
177
Rep 6,631
The Cobb maps some of us have tested maintain stock HPFP and LPFP pressure all while maintaining 12 AFR on upgraded twins. There's more in there for sure.
E90 LCI N54 6AT
06-02-2012, 11:25 PM | #15 |
70
Rep 2,197
06-04-2012, 07:54 AM | #17 | |
292
Rep 2,898
Neil |
06-04-2012, 08:13 AM | #18 |
177
Rep 6,631
Easily.
E90 LCI N54 6AT
06-04-2012, 08:16 AM | #19 | |
68
Rep 1,432
So, what do you mean by a good fuel pump? An upgraded one? OP wonders if upgraded fuel pumps are under development or not and if there is a need for them. |
