Brake Wear Sensors Needed?
05-31-2012, 08:17 AM | #1 |
14
Rep 109
I recently took my 2007 328i to the dealer after noticing a squeaking sound coming from my passenger rear brake (rolling at low speed and under light braking). Since I am still under CPO and MP until this September, I did not spend any time researching possible causes on my own. Turns out, I have a pretty well documented issue where the brake wear sensor which touches the rotor is the cause of the sound. The dealer is going to replace pads (and possibly rotors) on all four corners which is fine with me, but the existing pads still had a good amount of life on them.
What would happen if wear sensors were not installed with new brakes? I am happy to have my brakes replaced for free but I am just concerned this issue might occur again in the future when I would have to pick up the bill. To me, the benefits of the sensor don't seem worth it. However, I would not want a dash light or something similar that occurs when you run wheels without TPMS. Any input is appreciated! |
05-31-2012, 10:01 AM | #2 | |
81
Rep 1,510
05-31-2012, 01:24 PM | #3 |
15
Rep 153
Your sensor might have made contact with the rotor, when the sensor isn't secured properly to the caliper brake fluid bleeder valve protective cover. Someone who flushed your brake fluid might not have attached the sensor wire to the bleed valve dust cover allowing part of the sensor to come into contact with the rotor.
06-01-2012, 06:11 AM | #4 |
17317
Rep 18,740
+1. If you want to keep the sensor from making noise you can remove it from the pad and keep it connected. However, the car is expecting to see brake pad wear, so you may over time get the CBS out of whack and it start showing false indications of pad replacement. The system works using a 2-stage wear sensor. The CBS has an expected wear rate formula that is then augmented once the first stage of the wear sensor is reached. This data is used to estimate the remaining pad life, which is one of the menus in the CBS. The car is going to travel miles and not see any brake wear, so it might make the CBS think there is a problem with the system.
06-01-2012, 07:29 AM | #5 |
14
Rep 124
I don't buy into the theory that this common "low speed rolling rear brake squeak" is related to brake sensors. It just does not sound right and after replacing my own brakes it does not really make sense technically to me. You should by all means accept new rear brakes from the dealer if they are offering that as a solution but I bet the sound will return quickly as others have reported. I personally believe in this theory and will be trying it myself in an upcoming weekend: http://www.e90post.com/forums/showthread.php?t=697365
06-01-2012, 01:52 PM | #6 |
14
Rep 109
Thanks for the replies. I'm headed back to the dealership on Monday, so I'll get more info on what exactly they say to be the problem and what will be replaced. At this point, I guess I'm happy to get the brakes freshened up for little or no cost before my CPO and MP expire. Based on the response about a dash light, I'll definitely want to have sensors intalled.
Sonorous, the only the I can say to support the dealer's diagnosis is that I read the wear sensors are installed on the passenger rear and driver front brakes, and I could tell my issue was coming from the passenger rear brake. The technician told me their was a service bulletin about this particular issue. It sounds like there are some work arounds with the sensors if this is in fact the root cause and I face the same problem again on my own dime. |
06-06-2012, 04:55 AM | #7 | |
25
Rep 642
I had my pads ground so that the edge is not flat. On my Audis, this would eliminate squeaking completely as it allows the small metallic bits of brake dust to fall away instead of getting stuck between the pads and the rotor. On my BMW, this helped somewhat, but the problem still comes back and goes away on its own accord. More confusing, nothing looks glazed, and the coming and going of the problem seems independent of brake temperatures as I sometimes get squeaks on first brake application and sometimes after a nice/spirited bout of mountain driving where my brakes are HOT. The mysterious squeak! |
