05-29-2012, 08:23 PM | #1 |
148
Rep 379
Best audio quality from Ipod/USB
What sound format do you use for the best sound quality?
The standard default I tunes format produces only average sound quality in my standard sound system (9 speaker HiFi: Non Harmon Kardon). I also found using Apple Lossless format, the quality is still inferior to the same music played on the CD.
BMWphile
2020 G20 330iM Sport (Tanzanite Blue), Visibility, Comfort, HK 2012 F30 328i Sportline (Mineral Grey) Last edited by Bmwphile; 05-30-2012 at 05:17 AM.. |
05-29-2012, 08:34 PM | #2 | |
101
Rep 1,237
05-30-2012, 11:10 AM | #3 |
37
Rep 348
FYI there is a reason it is called 'lossless'. FLAC and Apple Lossless and WMA lossless are bit perfect copies of wave files (cd or higher) The only limitation the iPod has is that it has a crappy DAC and can only do 24/48 Max.
I only mention FLAC as I use that format in home systems. Otherwise I use apple lossless for my car ipod as well. If you don't have enhanced USB, sound quality will suffer a bit. |
05-30-2012, 05:02 PM | #4 | |
148
Rep 379
I don't have enhanced USB, but would I get any better quality using a USB drive instead of the IPOD?
BMWphile
2020 G20 330iM Sport (Tanzanite Blue), Visibility, Comfort, HK 2012 F30 328i Sportline (Mineral Grey) |
05-30-2012, 08:49 PM | #5 |
37
Rep 348
In theory yes. The car's DAC should be nicer so music should sound cleaner. Assuming the same format limitations exist in the f30 as my dad's 09 335i, you can at least play wma lossless files (16/44 max resolution). I have a decent amount of hi res music (24 bit) so I will have to downsample those tracks - but everything will be at least CD quality and a digital transfer to the head unit.
I am going to do a little A/B testing this weekend on the 335 again to see how my 24 bit music on the ipod sounds vs 16 bit via USB. I'll report back.. |
05-31-2012, 06:56 AM | #6 | |
148
Rep 379
BMWphile
05-31-2012, 03:56 PM | #7 |
37
Rep 348
06-02-2012, 02:00 PM | #8 | |
452
Rep 2,148
Drives: F87 M2 BSM MT
06-02-2012, 10:25 PM | #9 |
148
Rep 379
When you rip from a CD in ITunes, there is a button for "import sttings" set this to "Apple Lossles encoder"
BMWphile
06-19-2012, 03:00 AM | #10 |
37
Rep 348
yeah or if you are converting from flac you can use dbpoweramp. thus far my f30 isn't able to play wma lossless like my dad's e9x, not sure why. Plus BMW didn't include the iPod adapter. thankfully I just remembered I copied my mp3 80s and classic rock mixed folders to the ssd so we will have some tunes. I am going to experiment a bit tonight when we get to Vienna. Otherwise I have to say the HK system sounds noticeably better than my dad's Infinity/hk system.
06-19-2012, 12:21 PM | #12 |
woof
82
Rep 1,233
For what it's worth, I notice a significant difference on the M3's Individual High End Audio system when playing music from a usb hard drive vs. the aux jack.
Sounds obvious, but I didn't realize it until hearing the same songs both ways. I believe playing thru USB (or iPhone, iPod, etc.) preserves the digital output whereas the aux jack translates digital to analog.
2013 F13 ///M6 Sakhir Orange 2013 F30 335i Estoril Blue II 2008 E92 ///M3 Interlagos Blue 2007 E92 335i Montego Blue |
08-22-2012, 10:39 PM | #13 | |
148
Rep 379
Thanks for your help.
BMWphile
08-23-2012, 12:11 AM | #14 |
37
Rep 348
FLAC won't play over USB in any BMW. WMA lossless (16/44) plays fine in my dad's '09 335i over USB, but it doesn't work in my f30. I'm not sure why - may be something to do with having navigation or enhanced usb?? Wave files should play fine though.
Maybe you guys with nav and/or bmw assist can give it a shot. |
