Crap! Car full of water.
06-29-2007, 11:28 AM | #1 |
196
Rep 2,485
We had a serious storm last night. Turns out kid #2 left a rear window open and wife didn't garage the car.
Luckily I have leatherette but carpets are soaked in the rear. I told the wife to idle the car with the windows cracked and heat and AC running. Any other ideas?
2006 E90 330i (retired)
2009 E90 335i (retired) 2012 E70 X5 50i M Sport (retired) 2016 F10 535i M Sport |
06-29-2007, 11:30 AM | #2 |
///M Specialist South Shore BMW
770
Rep 7,108
park it in the garage and leave a dehumidifier running.I hope it doesnt get musty.good luck.
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
06-29-2007, 11:31 AM | #4 |
11
Rep 420
yeah shop vac your carpets. That is the best suggestion i could give you so you dont get the moldy smell. Yuck!!! It will smell like wet dog everytime you would go in your car.
06-29-2007, 11:32 AM | #5 |
ni2009
23
Rep 288
holly carp. sorry man, i think that is the worst moist problem i have ever heard of.
try removing the water intially with paper towels. place them on the carpet and then place a heavy object on top of the towels. the water will be abosrbed into the towels due to capillary action. then try using a blow dryer. also you can purchase some power heat guns from hardware stores (just be careful as they are able to burn both you and the carpet). |
06-29-2007, 11:36 AM | #6 |
119
Rep 2,909
Put rice on the carpets... I'm not joking either... The rice will absorb all of the moisture.
Also, rice works great if you've immersed your phone/pda in water. |
06-29-2007, 11:59 AM | #7 |
76
Rep 2,104
hahahahaha A RICE Cooker.... for 50K....j/k
SaaS - The world of tomorrow is already here...www.saaschronicles.com |
06-29-2007, 12:22 PM | #8 |
Now With 33% MORE Sarcasm Free!
157
Rep 3,462
Open the Windows, put a fan blowing in and a fan pulling out. Leave it for a little while. If you can get it indoors and out of the humidity so much the better.
Rice sounds like a good idea...
A BMW is Just a Car, it doesn't make you smart, handsome, clever, better, cool, or wealthy. |
06-29-2007, 12:26 PM | #9 |
558
Rep 6,169
I wouldn't idle the car for long period of time...not good for the engine...
Just use a shitload of paper towels...open all the doors and window and air it out inside the garage...
MKIV 6spd 1000hp Club |
06-29-2007, 12:35 PM | #11 |
Smiling politely
165
Rep 7,931
Don't mean to panic you any more than you already are, but you need to address this RIGHT AWAY. Once mold sets into carpet padding, it's almost impossible to get rid of it. I suspect BMW and most cars have some sort of mold-resistant padding, but it can only work so well.
Wet vac first. Then air flow is an absolute key. Pull the floor mats and set up fans to blow through the car. Your floor mats can be hung outside to dry. Borax can be sprinkled on the carpet if you like -- it kills mold spores, is gentle enough to use on carpet (unlike, say, bleach), and can be vacuumed up later. I've never heard of using dry white rice before but it sounds like a decent idea. It's a desiccant that you can easily vacuum. Watch out for accidentally spilling any rice into your air vents under the front seats! As an aside, Borax in the air vents would not be a problem. BTW - I don't mean to sound like an expert, because I've never had to do this for a car. However, I'm pretty good about knowing how to clean things around the house, and this is the method I'd use to save carpeting in the home after a very large spill or flood.
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
06-29-2007, 01:20 PM | #12 |
8
Rep 309
Great ideas in this thread. I agree with others and would not idle the car. Use a wet/shop vac to get as much water out as possible. Open all the windows in the car and place fans blowing in/pulling out air near the opened back doors (leaving the car in the garage). Never thought about the borax or rice but why not try that. Or try those pet urine carpet cleaners. They are a powder that soaks up the spot and can be vaccumed out. As often as you have time use a blow dryer and try to speed up the evaporating process. Its going to be a pain to get the water cleaned up but the alternative of a smelly car is a lot worse. When its dry use a lot of fabreeze or other odor killer - you will have odor no matter what you do. Dont use an odor masker as the smells will keep coming back.
This probably wont help but a similar thing happened to a friend. His sunroof was left open. Not only were the carpets wet but water got into the seat padding through the stitching. Beware of a soggy seat sound even if you don’t feel wet sitting down. The vinyl will keep you dry while holding in the water that got into the seat padding. After he wet vaccumed as much as possible my friend took the car to a body shop and paid the guys to park his car in the "oven" for a couple hours. Better auto repair/paint shops have these dust free rooms where they paint the cars then bake the paint onto the car. They thought he was crazy but it sped up the evaporation. Unfortunately some smell was still there and he eventually sold the car after killing the smell as much as possible. Good luck. |
06-29-2007, 01:59 PM | #15 |
11
Rep 613
I dont know if the BMW has one but my A4 had a rubber plug to drain liquids out incase of spill during an accident. The plug was underneath the car between the front and passenger door.
06-29-2007, 02:36 PM | #16 |
62
Rep 1,141
Who the hell told you this? Although it would be dumb to let idle for like an hour. It should not cause any harm.
06-29-2007, 02:49 PM | #17 |
Klaatu Barada Nikto
30
Rep 1,169
After you shop vac and blot out all water you can, get some of these puppies and put them all over the surfaces where the water was. They will grab up what's left very well, then just pitch them. I've tried them and they work.
http://www.drytheair.com/xcart/store...gs_page_1.html |
06-29-2007, 03:04 PM | #18 | |
558
Rep 6,169
Google told me that, that's who the hell told me.. Because the engine isn’t working at its peak operating temperature when it’s idling, the fuel doesn’t undergo complete combustion. This leaves fuel residues that can contaminate engine oil and damage engine parts. For example, fuel residues tend to deposit on spark plugs. As the amount of engine idling increases, the plugs’ average temperature drops, and they get dirty more quickly. This, in turn, can increase fuel consumption by four to five percent. It’s a vicious circle of wasted fuel and needless greenhouse gas emissions. Excessive idling can also let water condense in the vehicle’s exhaust. This can lead to corrosion and reduce the life of the exhaust system.
06-29-2007, 03:51 PM | #20 | |
35
Rep 521
If I were you, I'd take the keys away from your wife and hit the window lock button. |
06-29-2007, 04:14 PM | #21 |
56
Rep 661
the same thing happened to a GTI I had and a few years later to my e46. Both caused by some asshole junkies who decided to break into my cars when they were parked outside during a rainstorm.
I tried using fans, but the GTI was never dried out properly, and it never really got rid of the smell. In the case of my e46, I insisted that the insurance co pay to have the car properly dried out. They gave in and I took it the BMW dealership and they did a proper job of drying it out by removing the seats and using high powered fans and heaters (I think they may have also lifted the carpets). I never had any further problems with condensation or smell. Based on my experience, I would recommend you spend a bit of money on this if you can't do a proper job yourself. |
