Auto trans fluid
05-24-2012, 09:21 PM | #1 |
Rep 22
Auto trans fluid
I did a search on auto trans fluid but that just confuse me more. What I found out was that the BMW lifeguard fluid was basically the same as mercon sp that's new fords are using. I don't know what fluid to get its either the shell spec or redline couldn't find much on redline fluid either. What I want is a whole kit for my trans because my sleeve is leaking if not what kind of kits are they?
05-25-2012, 12:31 AM | #2 |
164
Rep 2,556
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
05-25-2012, 01:29 AM | #3 |
812
Rep 3,974
I used Pentosin ATF 1 in the 2008 335i with great results in hundreds of qtr mile tests, etc.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
05-25-2012, 07:02 AM | #4 |
547
Rep 2,590
05-25-2012, 08:19 AM | #5 |
812
Rep 3,974
Nope, never had any trans problems except for trans limp mode (3rd gear default) when running way over 500 hp/500tq Other than that trans ran fine, and continues to run fine. Cracked my trans pan on a rock early in the life of the car, filled it with this fluid, and trans seemed to run better than ever. One forum member said this fluid is superior to the factory fluid.
05-25-2012, 08:28 AM | #6 |
21
Rep 396
Drives: e90 335xi
http://www.ecstuning.com/BMW-E90-335...ion/ES2523893/
Trans leak on my 335 after 50K... This is what I got
05-25-2012, 12:13 PM | #7 | |
17
Rep 372
since they have been known to leak, but it can be a pita since there isnt much room. |
05-25-2012, 12:20 PM | #8 | |
164
Rep 2,556
05-25-2012, 12:25 PM | #9 |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
Probably don't need to replace the Mech Sleeve once its been done, the new one is a revised part that shouldn't leak.
05-25-2012, 12:32 PM | #10 |
164
Rep 2,556
^ Not taking that chance. Might as well replace it with the pan/filter and fluid.
05-25-2012, 01:46 PM | #11 |
Rep 22
I'm between those two kits price difference isn't to bad I just want to make sure which fluid is better. I been searching and I keep reading bad things about lg6 oil but nothing on the redline fluid. I think I'm just gonna play it save and get the kit from cts and the sleeve.
