missing injector o-rings = new cylinder head?
05-24-2012, 08:27 PM | #1 |
166
Rep 906
Drives: 2008 535xi / 2011 Z4 35Is
All 6 six injectors were installed by a dealer without the o-rings.
What does the damage to the cylinder head look like when this happens and what sort of diagnosis routine would a tech follow to declare the cylinder head should be replaced or not? |
05-24-2012, 09:47 PM | #3 | |
184
Rep 2,841
Pretty sure the rubber ones are the ones that seal. |
05-24-2012, 09:53 PM | #4 |
166
Rep 906
not sure because I didn't get to see it. My dealer said all six were installed missing something and therefore the cylinder head needed to be replaced. The dealer that made the mistake wants to look at it of course and I suspect will declare the cylinder head is fine. I am just wanting to understand more about what a tech would look at to make a decision either way.
05-24-2012, 11:06 PM | #5 |
915
Rep 3,456
Drives: Harrop E90 M3
Soot or exhaust residue around the injector. Probably the decoupling elements that were missing since the car wouldn't run long without the injector teflon seals that seal them to the head. The decoupling elements work like shock absorbers since the injectors are in the cylinder- direct injection ad allow the injector to move. If they are missing, the injectors move too much and an wear the cylinder head around the injectors. Then you have a compression leak around the injectors and misfires as a result. If the head is worn in the injector bores, there is nothing that can be done to fix it short of head replacement. Bum deal, but at least it's not out of your pocket. It's a good time for them to clean the valves when they have to swap them to the new head!
05-25-2012, 07:40 AM | #6 | |
166
Rep 906
05-25-2012, 08:00 AM | #7 |
31
Rep 635
Same thing happened to me with one injector installed by a dealer. It caused misfiring about 6 months after replacement and after about a year it got really bad/annoying to drive. When I took to another dealer they said the previous dealer installed the injector incorrectly forgetting some retaining clip.
[19" VORTEX TUNING LM's]
[JB4][BMS DCI] [CYBA INTAKE SCOOPS] [M3 REP FRONT BUMPER] [H&R SPORT W/ KONI YELLOWS] [MATTE BLACK GRILLES][VRSF DOWNPIPES][GLOSS BLACK VINYL ROOL][LIP SPOILER] http://www.facebook.com/thelastdetailnv |
05-25-2012, 08:27 AM | #8 | |
166
Rep 906
05-25-2012, 03:55 PM | #9 |
Some dude
92
Rep 1,780
Wow, that sucks! The dealer would be better off with just replacing the whole head. Trying to get a sleeve machined for however many injectors were affected, then reamed to size, etc, sounds like a recipe for disappointment to me. I'd only attempt it if I had to pay out of pocket and it were my own mistake on maybe one injector.
RRT
E92 335i/6MT with stuff and things |
05-25-2012, 04:57 PM | #10 |
166
Rep 906
Got word from our regional BMW rep that there is no "repair the head" option. If it is damaged it must be replaced.
I'm getting the impression the BMW rep is all over this and will ensure this is properly resolved. |
05-25-2012, 06:06 PM | #11 | |
184
Rep 2,841
What symptoms did you notice drivng the car? |
05-26-2012, 06:28 PM | #12 |
166
Rep 906
That's good to hear!
What symptoms did you notice drivng the car?[/QUOTE] Just the cylinder 3 misfire like any other. Only I couldn't remedy without trying a new injector and I am under CPO so I just mentioned the problem when I went in for our battery cable recall. Turns out it wasn't missing o-rings but the decoupling element that was mentioned a few posts back. |
06-07-2012, 11:51 AM | #13 |
166
Rep 906
This is how things turned out:
Both dealers really impressed me with their commitment to determine the extent of any damage to the cylinder head as well as BMW. The dealer responsible for the problem sent a driver with a loaner Mercedes 3 hours to pick up my car, took it to their shop and inspected and photographed areas of concern with the district BMW rep onsite to look at the problem first hand. Everyone is satisfied there is no cylinder head damage. They installed 6 new injectors (properly of course) and tested the car over a period of multiple sessions and brought it back to me on day 3. As far as the performance of the car, all I can say is that I am completely blown away at how fantastic the car feels! I thought it was great before (until my misfire problems) but I had no idea what I was missing out on. I have run a Procede before and this car feels to me like it is on map1 and a Procede isn't even installed. Cost to me: $0 and couple days in a Mercedes! The Mercedes by the way, a 2012 C300, was fantastically quite and smooth on the road but the performance was underwhelming. |
