HPFP Problem?
05-23-2012, 02:38 AM | #1 |
112
Rep 2,621
HPFP Problem?
I have been having problems when going WOT in 3rd and 4th Gears.
Started out with shuddering and misfires, now have more heavy jolt and limp mode triggered. The symptoms are most pronounced when getting on the throttle hard - particularly after changing gear. There are no codes raised! I did a few logs and Terry mentionned that the fuel pressure dropped off the chart. Is this likely to be the HPFP/LPFP or could it be faulty injectors etc? I have changed the sparks and coils, cleaned the VANOS solenoids and MAP sensors. I'm gonna replace the fuel pump and clean the intake valves next - unless anyone disagrees?!
Car: e91 330d with Viezu map
Gone but not forgotten: 2010 Jaguar XFR (Cat-back exhaust, pulley, intake mods and map), Highly Modified E90 335i LCI M Sport Manual (circa 480BHP/500lb ft) |
05-23-2012, 04:18 AM | #2 |
161
Rep 7,377
seems impossible no codes are thrown. You have the auto code clearing off?
05-23-2012, 06:40 AM | #3 | |
112
Rep 2,621
The only code raised is 3100 low boost mode engaged. I.e. an 'effect' rather than a cause.
05-23-2012, 06:43 AM | #4 |
112
Rep 2,621
Car has 84,000 miles without valve cleaning...
Original hpfp replaced at 30,000 miles.
05-23-2012, 06:51 AM | #5 |
161
Rep 7,377
i dont think is possible to get 3100 code without the one that actually caused it.
05-23-2012, 08:21 AM | #6 |
112
Rep 2,621
I got these codes a few weeks ago.
29F4 Catalytic converter conversion 29F5 Catalytic converter conversion 2 2D18 manipulation cover, maximum air mass 2F71 E-box-fan, input signal 3100 low boost mode engaged -- CEL displayed 0000 Failure location not implemented But Terry didnt think any of those codes would cause a limp.. Ps. Problem is there on Map zero.
05-24-2012, 02:38 PM | #7 |
112
Rep 2,621
Just got these codes:
2F71 E-box-fan, input signal 29F5 Catalytic converter conversion 2 29F4 Catalytic converter conversion 2A87 Outlet-Vanos variable cam control test, mechanics 3100 low boost mode engaged -- CEL displayed VANOS Solenoid replacement? Or something more serious?
