BOV vs Diverter Valve
05-21-2012, 03:11 PM | #1 |
Rep 57
Im currently running catless turbo back, intake, and Cobb. Will my stock divereter valve hold all the pressure of the cobb or should i get a BOV? Also someone told me these cars are meant to have the DV and dont do a BOV.
05-21-2012, 03:16 PM | #2 | |
3441
Rep 79,211
You have many options for upgrades including a Forge DV upgrade with the use of your stock charge pipe OR You can upgrade your charge pipe and use a Forge DV or other BOV like Tial HKS or Synapse. Any questions you can PM me or check out our site. |
05-22-2012, 10:48 AM | #3 |
79
Rep 2,396
Drives: '08 E90 335i
Assuming you're running Stage 2 on the COBB (since the only requirements are upgraded intake & DPs), I ran into the same issue. I called COBB & asked if there's anything else I should worry about/consider upgrading. They said on Stage 2, some people have experienced leaks on their OEM DVs & that I should consider looking for Forge DVs or something comparable to ensure that I don't have any boost leaks (in the end, I decided to also replace the CP to make sure nothing leaks/cracks on my DD running higher boost).
DVs vs. BOVs
IMO, BOVs are annoying (constant wooosh noise when it vents pressure) and are a bit cheesy, not for a BMW (not trying to make my car a Fast & Furious set piece). To each's own, personally I like the DV set up since that was what BMW used from the factory & I like my "silent sleeper" set up. |
05-22-2012, 08:16 PM | #5 |
45
Rep 676
with your dv's, do you hear more of the woosh then on the stock? i know they both very quite but i know my stock one you can sill faintly hear it
// JB4 ISO // Running Meth // Full FBO // E85 user //
05-23-2012, 11:02 AM | #6 |
26
Rep 497
Also note that BOV's run rich as it is venting metered air. A negative effect of BOV's.
08' 335xi 6MT Space Metallic Grey Premium, Nav, Cold weather, Sport Procede 2.5, DCI, Forge DV, PWM, Scoops, KW V1, ETS 5" FMIC, VRSF Downpipes, M3 Skirts |
05-23-2012, 11:12 AM | #7 |
3441
Rep 79,211
What do you mean? I havn't seen anything like that on this platform. I know on the Subaru platform people had those issues but they were on a MAF based system, but they just needed to tune for it. I believe that is only a myth for untuned vehicles or ones on MAF. We are MAP.
05-23-2012, 11:17 AM | #8 | |
79
Rep 2,396
05-23-2012, 11:25 AM | #9 |
Custom Powder Coater
147
Rep 2,784
U can get some "BOV"s and not get the "whoosh" sound. Just vent the air back to the intake tube like stock.. I know u can do that with the Synapse BOV.
Also u can get the whoosh sound from DV's as well, just vent the DV to the atmosphere.. U can even do that with stock DV's..
05-23-2012, 12:29 PM | #10 |
30
Rep 283
In my experience, the stock DV's work just fine for your application. In some instances, changing to upgraded DV's has led to surging and even underboosting. I would save the time and money and stick with the stock ones.
05-23-2012, 12:32 PM | #11 |
Rep 39
In my experience, the stock DV's work just fine for your application. In some instances, changing to upgraded DV's has led to surging and even underboosting. I would save the time and money and stick with the stock ones.[/QUOTE]
How? |
05-23-2012, 12:46 PM | #12 | |
79
Rep 2,396
Don't ask me why there is an overlap in the Yellow & Blue springs or why there is a 7 PSI gap between the Blue + Red springs. On OEM turbos most people use yellow., if you have RB turbos Blue might work best. |
05-23-2012, 12:46 PM | #13 | |
26
Rep 497
The thing is ur venting off metered air. The ecu has to compensate.
05-23-2012, 01:01 PM | #14 | |
8
Rep 704
Some cars have a MAP and MAF sensor. |
05-23-2012, 01:07 PM | #15 | |
3441
Rep 79,211
I've been running BOV on this car for 3 years seamlessly with no problems in controlling AFR and neither have the 100's of my customers. I think you are confusing other platforms and their problems;this is not a real problem on this platform. This ECU and system is completely different from the VW's. |
05-23-2012, 01:12 PM | #17 |
79
Rep 2,396
05-23-2012, 01:18 PM | #18 |
30
Rep 283
I hesitate to name a specific company, as I would rather keep this as a discussion. What I will say is that we have had multiple customers experience underboost issues with aftermarket DV's. They switched back to the stock ones to remedy the situation.
Since we are still early in our aftermarket turbo development, I cannot yet speak for the high levels of boost that will be seen in such builds. But for everything up to our Stage 2 Race, running 16-17 PSI, we have seen no problems with the stock DV's. And like you mentioned, some people use springs that are too stiff. If this happens, and excess pressure is not diverted upon throttle closure, you have a whole different problem on your hands. For what it's worth, if it were me I would save the money and keep the factory DV's on a stock turbo setup. |
05-23-2012, 01:21 PM | #19 | |
292
Rep 2,898
Neil |
05-23-2012, 01:29 PM | #20 | |
30
Rep 283
We are still testing the ceiling of the stock DV's. Since we haven't had a failure at this point, I really cannot recommend against them. For what it's worth, Evolution Racewerks is running their DV charge pipe with a Tial BOV on the GIAC Stage 2 Race 135i. They have not had any problems with this setup, even when pushing our beta file to 18 psi. |
05-23-2012, 02:00 PM | #21 |
79
Rep 2,396
05-23-2012, 02:05 PM | #22 | |
Joint Chiefs of Staff
4918
Rep 115,980
Basically it boils down to personal preference. Get a BOV if you like the sound. There are quiet BOVs like TIAL and then there are louder ones like Synapse and HKS. Its all a matter of preference. If you stick to stock DVs or Forge DVs then they operate pretty much silently. Mike |
