Any reason why I shouldn't push further? 20psi?
05-20-2012, 02:25 PM | #1 |
Team Zissou
3065
Rep 10,197
So I'm currently running ~18.5psi with meth. WGDC maxes out at 60-65%. Fuel trims and AFR look good.
Is there any reason why I shouldn't push these snails a bit further? to say 19.5-20psi? As long as WGDC isn't maxed out at 100% is there any reason to NOT raise boost a little more? Assuming I do make more power with more boost. Does running a higher WGDC (as long as it's not maxed) have any negative impact on turbo life? or is it negligible? Last edited by jpsimon; 05-20-2012 at 04:12 PM.. |
05-20-2012, 02:52 PM | #2 |
161
Rep 7,377
you can probably run more boost low - midrange and keep the high rpm the same.
05-20-2012, 03:10 PM | #3 |
68
Rep 1,432
You are running clipped turbine wheels, so you could and should run more boost to make both the power and back pressure to match the unclipped upgrades.
Edit: the aerodynamics is not as good, as unclipped, so you'll never actually match the power... |
05-20-2012, 03:30 PM | #4 | |
177
Rep 6,631
E90 LCI N54 6AT
05-20-2012, 03:36 PM | #5 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
All things equal clipping a turbine wheel does not reduce power. What it does is potentially reduce exhaust back pressure at the expense of turbine efficiency (which has a negative impact on boost response).
05-20-2012, 03:47 PM | #6 |
Team Zissou
3065
Rep 10,197
I guess a better question... assuming I do make more power with more boost. Does running a higher WGDC (as long as it's not maxed) have any negative impact on turbo life? or is it negligible?
05-20-2012, 09:50 PM | #7 |
Rep 538
I prefer to cap WGDC at 80% since the wastegate is nearly closed at that point. There's a point of diminishing returns when you crank up the boost with small turbos. Backpressure in the exhaust manifold can rise quickly with little added boost. It's still beneficial to crank up the boost just after spoolup to get a nice torque hit, as long as you can balance the boost spike with good fuel and timing. Just make sure the boost tapers down as rpm climbs so the engine doesn't choke with extreme exh backpressure.
05-20-2012, 10:11 PM | #8 |
278
Rep 5,062
Drives: Black e92 335i
I'm thinking of going with a turbo setup very similar to the EPL's with a couple extra things added to try get them working better. I would be very interested in seeing the results of how they respond to more boost and how well they can hold the boost.
JB4 / OSS Angel Eyes / Downpipes / F1-Racewerks FMIC / Custom Meth Kit / BMS DCI / ER Chargepipe / HKS BOV / BMS Meth Elbow / BMW Performance Exhaust / Carbon Fiber Inlay Quad Tips / 19" Miro 111 / Front Aero Lip / M3 Sides / VRS CSL Trunk / Mtech Rear / DD CF Quad Finned Diffuser / LCI Tails / BBK / Smoked Reflectors / F1 Euphoria LED Interior / License LED's / GT 5000k Corners / 5000k HID Fogs / Air Scoops / LED Turn Signals / FK Silverline Coilovers / HPA endlinks / Vibrant Resonators / Osram CBI 5000k D1S
05-20-2012, 10:19 PM | #9 |
Team Zissou
3065
Rep 10,197
Ill post up the results when i get back on the dyno. Waiting on a trunk-mount meth tank to come then I'll run a higher % meth mixture when doing this
05-20-2012, 10:24 PM | #10 | |
1737
Rep 17,960
Drives: A Lot
05-20-2012, 10:39 PM | #11 |
114
Rep 2,428
Here's a question- Is there any worry of bending a rod from the massive torque at 3500rpm?
I haven't seen any rod failures due to too much torque, and the Vishnu single turbo is capping torque around 500, so it's unknown at this point what tq level the rods will let go at. Because of that I'm a bit weary of cranking it up farther than my current 440whp/503wtq level. |
