Meth wooos
05-16-2012, 07:33 PM | #1 |
109
Rep 1,948
Meth wooos
I have the Pwm kit from Vishnu and it's just wierd. I have a trunk mounted kit but something is just not right! I was driving around today and it's mid 20C out here so warm. When I started driving, car warmed up, I get on throttle and meth is flowing great. Driving through town get an open stretch, get on it, no more meth flow
This is happening more often now! Pump throttle to basically prime system but still nothing. Come home, check lines and no leaks! I takeoff the lines coming from pump to FAV and it's pressurized with meth in it. I'm not buying this meth boiling over in the lines that much. I had the stage 3 system from snow performance and never had this issue. Now with snow, it was recommended to have an extra solenoid if we had a trunk tank to prevent flow back. Do we need that here as well? Ideas? Thoughts? |
05-16-2012, 08:40 PM | #2 |
Chump
10
Rep 173
If I had to guess, I'd say your Injection % value in the user settings is too high.
What did you set it to? Try lowering it to the default recommended value of 25 and re-test. I was having similar problems, I'd get solid meth indicators around town but when I'd get a stretch to go WOT, I'd get no indicators.
2009 e90 LCI Blacked Out Space Gray - Vishnu Procede 2.5 w/9-10 Aggressive Map Stg2 - PWM Meth (80%) - BMS DCI - VRSF Intercooler - VRSF Downpipes - HKS Cat-back Exhaust
05-16-2012, 09:51 PM | #3 |
109
Rep 1,948
my logs show the full flow setting to be 47. I had mine set to 42. I just dropped to 30 to test. I think it's most likely my FAV. i have to figure out a few things on this.
05-16-2012, 11:12 PM | #4 |
Some say...
239
Rep 4,296
Drives: Fresh
It's funny that you are saying this b/c I was thinking about making a thread about the same thing. Mine has been doing the same thing lately until the other day. I reached over and tapped the stalk that would pump washer fluid and spray the windshield and I guess it like primed it or something and it hasn't done it since.
I have exhaust and an intake... |
05-16-2012, 11:21 PM | #5 |
109
Rep 1,948
My issue is a bit different as i'm using a closed system. I'm not using the windshield fluid holder and don't have check valves etc. i have a dedicated tank in the trunk and a dedicated line. I have primed many times. Works for a few times and then stops. I'm thinking it's the Fast Acting Valve. It's possible it could have been damaged as BMW has been doing work on the car and they have been taking the system apart.
05-17-2012, 06:45 AM | #6 |
29
Rep 1,551
You should install a check valve if you trunk mount. Theres a lot more tubing involved when relocating the tank.
Remove the nozzles, put it in a bucket. Jump boost switch to turn on pump. Take off the connecter to the FAV, and jump the two top pins with a 9V battery. It should be a pure mist, you're essentially running at 100% DC. If your FAV is on the fritz, then it wont be a consistant flow/mist. |
05-17-2012, 11:24 PM | #7 |
109
Rep 1,948
So figured out my issue today. It is the check valve. When i opened the wire harness, there was rust on the terminals! Somehow, water got in hence why i'm having intermittent issues. I have my new Fast Acting Valve come in tomorrow. Once i get it, i'll verify. Also had a chat with Jeff Howerton. Awesome guy. He mentioned that we 'should' keep the the Valve as cool and dry as possible.
Also, he said there is no issue having the pump and tank in the trunk and connecting it straight to the Valve. |
06-09-2012, 08:49 PM | #8 |
109
Rep 1,948
So finally got another Fast Acting Valve and the issue still happens!! I can run through 1 or 2 WOT's and then meth will randoming stop flowing. On my logs, you can see that the Procede is asking for 100% DC on the meth system but no flow. Sad but never had these issues with my snow kit.
So far, bought new fast acting valve, changed relay and fuses. Checked wired connections. Replaced the tubes just in case there was a cut or leak. I run a in trunk PWM meth kit. I dont use a check flow valve and have a dedicated tank. My tank and pump are setup like FBIS had set his up in the trunk. I figure i have 2 more things to try. I have my older AEM pump vishnu sent out before the new pressure fitting ones so i'll replace my aquamist pressure fitting one with the older one in case it's a pump issue. Only other things left on the system would be the boost switch or the flow rate valve. This has been going on since april and im getting tired of this! Talked to Jeff Howerton who says maybe i should look into a aquamist kit. Really considering it. |
06-09-2012, 09:35 PM | #10 | |
109
Rep 1,948
Yes, it does work randomly. I will go 2 - 3 wot's and it works perfect. Do a 3rd gear pull and still works. Do another 3rd gear pull and not working anymore. Partial throttle, nothing. Again, partial throttle, i have flow now. Do a wot, part way through 3rd gear, meth stops flowing. I would almost say a loose connection but all connections have been checked. As mentioned, relay replaced, FAV replaced, Fuse replaced, ECU wire connections checked. |
06-10-2012, 01:48 AM | #13 | ||
Macgyver
208
Rep 942
GTX3076R , ADV, JB4, FMIC, BOV, 17"APEX, 255/40/17 SQ, 6-SPD Manual
06-10-2012, 11:59 AM | #14 | |
109
Rep 1,948
I did check the ecu connector and verified that. Its all connected nice and tight. |
06-10-2012, 10:29 PM | #15 |
109
Rep 1,948
So went through entire system again. Took wiring apart, re-did the entire wiring, soldered every connection. Replaced Fuse and relay again. Checked wiring to pump and tested boost switch. All check out. Took the car for a boot and meth stopped flowing again. This time, it wouldnt come back on at all! Came back home, and connected a hose post Fast Acting Valve dumping into a plastic bottle. Activated the boost switch and triggered the FAV. Meth flows perfectly. ran it off and on for a minute and no issues. Ran that hose with bottle into my cabin and went for a drive. When meth activated, it ran and pumped fine but ended up getting a meth overflow code. Restarted car and tested again and again, flowed on partial throttle. Pulled over, and connected the meth back to the charge pipe. Ran a few times and meth is flowing but too much traffic so came back home. Will try later tonight!
06-10-2012, 10:59 PM | #16 | |
18
Rep 462
06-12-2012, 12:17 PM | #17 |
109
Rep 1,948
Do you have a windshield mounted kit or trunk mounted? Most likely for you, meth boiled over or you had a bit of air in the system. Most people have this issue and usually you just have to activate the windshield washer pump briefly to prime the system and meth starts flowing again.
06-12-2012, 08:01 PM | #19 |
109
Rep 1,948
I've been testing it for 2 days and all is working!
I believe it was the connections going to the relay. I took all the wires apart, bought a new relay with harness, soldered all connections to that. Replaced fuse holder as well. Primed systems and all working now! |
06-12-2012, 10:32 PM | #20 | |
184
Rep 2,841
I guess you got the harness from Vishnu seeing as it is marries into the Procede? |
06-12-2012, 10:40 PM | #21 | |
109
Rep 1,948
I think it will. I had some issues with my car and my dealership had to take the system apart a few times. I also have the dinan CAI so they would literally have to take the meth kit, the dv's and part of the cai apart to resolve some issues. The relay as on the same side so i'm thinking the wires got stressed and damaged. I drove my car out to Trona in February and had no issues with meth. Had some fuel trim issues on the way back and the dealer discovered that one of the turbo inlet clamps were not sealing. To do the smoke tests etc, they had to take all this apart a few times. So far, very consistant as it was before. Just a pain in the ass to troubleshoot but between Jeff Howerton (awesome guy) and Shiv (Also awesome) we narrowed down what it couldn't be and worked from there. |
06-12-2012, 10:41 PM | #22 | |
3431
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
