BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > bmw 335i dyno test. what result ?
      05-16-2012, 03:42 PM   #1
buta
Drives: E92 335i
Mods: (JB4) (intake) (Downpipes) (Intercooler)
(Exhaust). map2
Is it a good result ?
      05-16-2012, 04:54 PM   #2
bigdnno98
Real Car Enthusiast
bigdnno98's Avatar
Germany
288
Drives: 340xi
What were your baseline numbers?
      05-16-2012, 05:04 PM   #3
Wedge1967
Drives: '07 e92 AT Sport Montego Blue
Looks good. I'm running a Procede with the same mods and see about the same numbers on a mustang dyno. Dynojet will run higher numbers from what I've seen, but it all depends on calibration. I haven't read much on the JB4 E85, but looking forward to some E85 maps for the Procede. Rumor has it 50/50 makes some really good power over pump alone.
Anyway, nice pull. Hopefully you logged. I'm sure a few guys will want to see the logs and can provide you with some good advise. Need to remember with high compression and high boost, your spark gap needs to be reduced. This can have an impact on your dyno numbers at high RPM...
      05-16-2012, 05:13 PM   #4
BEAR-AvHistory
2020 Z4 M40i - 2022 M4C Convt
BEAR-AvHistory's Avatar
Drives: 2020 Z4 M40i - 2022 M4C Convrt
What octane? Also a base line is good to have to see an apples to apples increase with the new gear.
My JB4 on 94 octane did 365whp on a dynojet with the old non-335is map.
Have not run the new 335is Map 6 yet. Car had no other mods on the dyno run.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers
2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT
      05-16-2012, 06:13 PM   #5
335twins
335twins's Avatar
Drives: 2020 x3 M40i, 2019 M2Comp
I got 350whp with drop in filter and flash (custom flash from a local performance shop), no downpipes and intercooler yet.
      05-16-2012, 06:42 PM   #6
Mike@N54Tuning.com
Joint Chiefs of Staff
4918
Drives: 2007 335i, 2015 M3
Try the new 5/11 map 5 yet? Might be even stronger!
Mike
      05-16-2012, 06:51 PM   #7
BEAR-AvHistory
I have not tried Map 5. Will take a look, but traction is already a problem
Kevin
      05-16-2012, 06:55 PM   #8
2jzn54
41
Drives: 07 E90 335i 6MT
Same mods plus an sld/cps module I put out 400 whp 436 tq std i believe on a dj on 93. Fbo no tune as a base 310 whp 310 tq. For what its worth i ran on beat Filters and Oil.. Possibly plugs.. Nothing major but yeah. I've since switched to the new auto tuning map with a 50 50 e85 mix and I refuse to return to 93 only.
      05-16-2012, 07:11 PM   #9
E90Company
E90Company's Avatar
194
Drives: Car
The results really vary from dyno to dyno, you need a baseline in order for us to tell you how great of gains you had.
      05-16-2012, 11:48 PM   #10
2jzn54
41
yes i should mention your results look good as dyno dynamics generally read 10-12% lower.
