BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Brake lights wont go off...?
      05-16-2012, 01:13 PM   #1
colt9987
45
Drives: 135i
For some reason my brake lights are continuously staying on...any ideas why this might be? I have no warnings or anything for their being a problem on my dash. I also have a procede...dont know if that matters.
      05-16-2012, 01:28 PM   #2
rader1
70
Drives: Cobb Stage 2+ 135i
Do the lights stay on when the car is turned off?
      05-16-2012, 01:29 PM   #3
colt9987
45
Drives: 135i
no when the car is turned off they turn off
      05-16-2012, 01:32 PM   #4
onebadmofo
onebadmofo's Avatar
346
Drives: 2008 E90 M3
Broken switch on brake pedal?
      05-16-2012, 02:09 PM   #5
JamesM3M5
Some dude
Drives: E92 335i
Make sure your pedal returns all the way back. There is a hall-effect switch that just sees the metal from the prake pedal go away and tells the footwell module to turn the brake lights on. As a backup, the DSC also will turn on the brake lights if it sees pressures above a certain threshhold. You may have to check for codes - brake pedal switch implausible, something like that.
You may just have a bad switch or more likely the pedal is unable to return all the way to the switch.
RRT
E92 335i/6MT with stuff and things
      05-16-2012, 03:58 PM   #6
colt9987
45
Drives: 135i
So how would I go about fixing this? can I just look back behind it and see if anything is loose?
      05-16-2012, 04:07 PM   #7
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Are you sure its the brake lights and not the taillights with day time running lights engaged?
When you have daytime lights on your taillights are on too.
Go through your menu and disable your day time running lights.
      05-16-2012, 04:10 PM   #8
colt9987
45
Drives: 135i
Yes I'm positive its the actual brake lights and not the daytime lights. I checked that first because I thought the same thing.
      05-16-2012, 04:14 PM   #9
Ah ok
      05-16-2012, 04:19 PM   #10
EastCoast335i
EastCoast335i's Avatar
Drives: 2015 X5 | 2008 335i
Could it be the rear fog lights are engaged?
      05-16-2012, 05:15 PM   #11
rader1
70
I would think if it was the brake switch wouldn't the lights would stay on when the vehicle is turned off. A VW I had had that that issue and even with the car off and key removed the lights would be on.
      05-16-2012, 05:48 PM   #12
onebadmofo
onebadmofo's Avatar
346
Drives: 2008 E90 M3
With these cars you need ignition to be on for the brake lights to come on.
      05-16-2012, 05:54 PM   #13
JamesM3M5
Some dude
Drives: E92 335i
Correct. Very annoying to have another brand of car on the alignment rack, install brake stick to hold the brakes, key off, and the damn brake lights are still on!
You will have to pull the lower cover under the driver's dash area to see the brake pedal switch. Ensure nothing is hanging up and holding the pedal down, even a 1/4" will turn the brake lights on. Aftermarket stereo or additional wiring up under the dash is typically quite shoddy and could be the cause. Otherwise it would be a bad switch.
RRT
      05-16-2012, 09:45 PM   #14
vase330
vase330's Avatar
Drives: 19 E63S; 15.5 RangeRover ATB
Jeff my car has daytime lights and only the front come on all the time. The tail lights only come on when it turns the actual lights on because the sensor detects low light or time is around 8pm (I have it on auto). Yeah am 100% sure only the rings stay on all the time not the tail lights. A buddy of mine has new 2012 F10 5series and it acts just like my car so maybe there is something wrong with your car.
E92 335 | Space Gray | Saddle Brown Dakota | Dark Burl Trim | ZPP | ZSP | AT | Idrive | 6FL | FBO | Dinan CAI | Quaife LSD | STG3 PROCede.
      05-17-2012, 09:17 AM   #15
colt9987
45
Drives: 135i
how hard is it to pull that lower cover off? and if it is a bad switch what are my steps on fixing this? i pulled back on the pedal to see if it wasn't coming all the way back up or something and it all seemed fine but brake lights are still on...
      05-21-2012, 09:10 AM   #16
colt9987
45
Drives: 135i
any idea on the part number for the brake switch?
      05-21-2012, 12:05 PM   #17
My tailights are always on with the day time running lights but then again maybe its only at dusk. I have a 2009 though. Maybe my car is possessed.
      05-21-2012, 04:06 PM   #18
JamesM3M5
Some dude
Drives: E92 335i
61 31 6 967 601 should be the correct part number. Order online at getbmwparts.com or other parts warehouse of your choice.
RRT
      05-22-2012, 01:27 PM   #19
colt9987
45
Drives: 135i
I changed my brake pads the other week and replaced the sensor and reset the brake service...but could it be possible I did not install the sensor correctly and this cause my rear brakes to stay on all the time? remember that I have no errors or anything on my dash
      05-22-2012, 03:41 PM   #20
alnk1015
Drives: 2007 BMW 335i German Import
No
Look for that switch your brake petal hits
      03-27-2016, 01:25 PM   #21
alex_beridze
Drives: BMW 335 2008 Year
Hello
do you solve this? i have same problem too
      12-09-2016, 01:14 PM   #22
3k1n
Drives: Subaru Sti
Does anyone know the part number for the module for the third brake light? I was told I needed to replace it.
