Sonic Coilover Install
05-16-2012, 12:44 PM | #1 |
85
Rep 1,356
I am getting the Sonic Tuning Coilovers this week and was going to install them and also new tension struts.
Is there anything special I need to do, any type of torquing or anything. I have read on the forums but dont know what needs to be done Also, whats a proper height setting from experience just to get rid of wheel gap. I have 19" Wheels. 8.5 +35 in front and 10 +38 in the back 235/35/19 and 236/30/19 Appreciate the help! |
05-20-2012, 04:02 PM | #5 |
163
Rep 2,979
Drives: 07 SBM E92 335i 6MT
The main thing is to decide on which bolts to take out on the rear control arms. If you do the inners, the install is easier but you're playing with the camber. The outers were a bitch to get back in...but your camber stays the same.
And when you take the top nuts off in the rear, don't let them fall down...you'll never get them out. Other than that, the rear is pretty straight forward. Have two jacks, consider cutting holes in the rear trunk liner so you can adjust the dampening on the fly...can't think of anything else right now.. On the front, don't worry about getting the top nuts too tight when you have the assembly off the car. You'll only be able to get them so tight anyway at that point. You'll have to tighten them after you get everything back on. And even then, you might have to tighten them a couple times to get no noise. I had horrible luck with my sonic tuning coils....hopefully it'll go better for you... As far as ride height....don't really know what to tell you there...the lower the better as far as I'm concerned lookswise. But perfectly flush and you might be scraping... There are a couple DIY's on here but they're for an E90....but the E92 is the same with this job...
In the process of restoring an 07 335i
05-20-2012, 10:42 PM | #6 |
85
Rep 1,356
Thanks alot for the insight. Ill definitely follow that.
What about front tension strut installs. Any special advice for that Also I'm getting alignment done anyway so it's ok if I touch Camber |
05-20-2012, 10:44 PM | #7 | |
85
Rep 1,356
Also why did you have such horrible luck with your sonic tuning coils?
05-20-2012, 11:12 PM | #8 |
163
Rep 2,979
Not sure what you're talking about...need more detail?
05-21-2012, 05:15 PM | #10 |
163
Rep 2,979
The ride was just horrible to me....WAY too teeth grinding even on the softest setting. AS a matter of fact, I couldn't hardly tell a difference from the tightest-softest setting. And I had noises coming from the front even after two installs. I know everything was tight as hell too.
But I'm not saying this to disuade anyone from these nor am I trying to damn them. That was just my experience. I've read plenty of great reviews. And I sold mine to another guy who hasn't said anything negative either. I'm pretty picky about my ride but that was crazy rough. Even my yellows on the hardest setting aren't nearly as teeth grinding as those. But yet handle almost as well. I will say that my car handled like it was on rails with those. As long as I was on a smooth stretch, it was badass. It felt so planted. I don't know....maybe it was the install....but I don't think so....
05-21-2012, 05:56 PM | #11 |
85
Rep 1,356
well lets hope *crosses finges* everything is well with mine, I just came back from the shop where i am getting them installed at, they said it was a pain in the ass getting the coilovers installed in the sleeve, but other than that everything is good
06-13-2012, 12:41 AM | #12 | ||
311
Rep 3,572
When you set the coils to the lowest setting it's a softer ride than OE sports (with the same allowance of height travel) Quote:
if you do have any trouble or questions regarding adjustment just let us know. |
06-13-2012, 04:33 AM | #13 |
Bausman
63
Rep 1,817
06-13-2012, 07:28 AM | #14 |
163
Rep 2,979
Maybe that was the problem Jose. I didn't do the install so that's a problem right there.
