warranty work: everything done to my car, wow
05-16-2012, 08:37 AM | #1 |
46
Rep 676
2008 manual sedan with 36,000 miles on it currently under full warranty
1. Vanos solenoids (both @ 35k miles) 2. LPFP 3. HPFP 4. Active steering motor/box/system replaced (@ 30k miles) 5. Upper valve head gasket replaced (Was leaking oil @ 35k miles) 6. Rear break sensor 7. E-break adjustments 8. New Breaks in rear 9. Alignment 10. Steering wheel trim replaced (due to pealing rubber) 11. Driver window controls replaced (due to pealing of rubber) 12. Front shocks/struts replaced has anyone else had this many headaches as me?!
// JB4 ISO // Running Meth // Full FBO // E85 user //
05-16-2012, 08:49 AM | #2 | |
138
Rep 2,731
Anyway many of those seem normal for your car 2,3,5 Some are nice of them 10,11 Some are straight up maintenance, not warranty 6,7,8 9 was because of 12, pretty much should count as one item you made out good. smile. |
05-16-2012, 08:51 AM | #4 | |
46
Rep 676
05-16-2012, 06:16 PM | #6 |
Where'd my VTEC go?
481
Rep 6,067
brakes are a maintenance item. how is that a headache? did you expect brakes to never wear out?
and brake sensor and parking brake adjustment were part of the rear brake job.
05-16-2012, 06:55 PM | #8 |
302
Rep 4,444
Yea, I've have my Vanos, interior trim, turbo #1, wastegate #2, entire power system, oil filter housing and a few other things...
Considering the turbo replacement, wastegate assemblies, and power system were all in the thousands I'm a happy camper. |
05-16-2012, 07:20 PM | #9 |
16
Rep 495
Drives: 07 328i
Head, tranny, diff, few gaskets, door lock actuators and new seat matts.
07 328i
05-17-2012, 06:55 AM | #10 |
46
Rep 676
wow!
05-17-2012, 06:56 AM | #11 |
46
Rep 676
new seat matts?
05-17-2012, 12:54 PM | #13 |
45
Rep 1,754
Warranty up this week, here's my list:
2 New HPFP's, one early on about 20K, second under the recall (no symptoms, but failed pressure test) 3 new injectors, recall, failed test Broken hood latch, one, replaced. Replacement froze up, replaced again. Accelerator pedal assembly replaced, squeaking noises when lightly pressed Several re-programs, one for turbo noise/turbo delay, others after service visits to cure electroinc gremlins caused by failed programming during the service (can't they tell when the programming fails????) Driver's side window control module replaced (finally, after 3 visits) to cure auto-opening windows and sunroof problem Rear control arm bushing replaced, creaking in wet weather 1 seat rail cover replaced, came off and disappeared at some point, or wasn't there to begin with. Only found it when the other side popped off and I was trying to figure out what the heck it was. |
05-18-2012, 07:48 AM | #14 |
16
Rep 495
Drives: 07 328i
Nope they were damaged along the bolster on the driver seat.
07 328i
05-18-2012, 07:55 AM | #15 | |
52
Rep 968
05-18-2012, 07:56 AM | #16 |
138
Rep 2,731
