Replacing brakes and need advice
05-16-2012, 08:37 AM | #1 |
8
Rep 67
I just got some new wheels and am tired of dealing with the dust from the OEM pads. Is there a popular opinion on the best performing/No to low dust pads? Are there any good deals out there on big brake kits? I don't really want to spend the money on Brembo, I do not track the car.
Thank you for any advice you have. |
05-16-2012, 10:22 AM | #5 |
104
Rep 1,529
dont get cool carbon...they suck for track and any kind of aggressive driving cause as they heat up they start breaking down. my brakes started to squeal so bad i changed them out to akebonos (which are pretty good so far).
after inspecting the cool carbons they have chunks missing from all over the brake pad...i read a thread about this happening and guess its true. but if you dont plan on tracking i guess this isnt an issue...sort of as all this happened while i was rebedding my pads because they were starting to squeal.
Space Gray l 6MT l OSG LSD w/ VAC Race Diff Cover l Cobb e30 l Morr vs8.2 l UUC SSK w/ DSSR l VSRF Catless Dps l RPI Intercooler l CDV Removed l HID AE 8000k l ETS Catback l AST 5200 w/ Vorshlag Camber Plates l ER Dual Oil Coolers l Rear Camber and Toe Arms l K&N Drop In l Solid Tranny/Diff/Subframe Bushings l Bridgestone RE-11
05-16-2012, 11:43 AM | #6 |
310
Rep 4,002
Virtually all brake noise/squeal is caused by metal to metal rubbing during
braking either on the piston face to backing plate contact surface or on the pad ears to carrier contact surfaces. Cool Carbon supplies instruction as to where to apply high temperature caliper grease and also products such as noise free to the piston contact area. http://www.coolcarbonperformance.com/faq.html While some install pads dry possibly without issue-this is not advised and generally can lead to noise later with any pad. We run these pads on our cars and many customers and have been extremely pleased on both the street and on the track- we have not experienced any temperature issues and have seen quite elevated temperatures. They are a street performance pad rather than a pure track pad but do perform well with light track usage. It is possible to fatigue any pad if the maximum operating temperature is exceeded. If you feel you have other issues please contact ourselves or Cool Carbon directly- they stand behind their product for all legitimate complaints.
Robert T. | european auto source (eas)
email: robert@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x21 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by robert @ eas; 05-16-2012 at 11:59 AM.. |
05-16-2012, 12:43 PM | #7 |
100
Rep 1,384
i went with the ebc redstuff, just got them put on last friday and they seem to be doing pretty well so far. i cleaned my car on sat and barely any dust on my wheels right now, had it been my stock pads there would already be a thin layer of brake dust. i did have to do the bed in process 3 times though to make squeal go away, and i get a tiny bit still just as the car is about to come to a dead stop
05-16-2012, 01:27 PM | #8 |
814
Rep 3,953
My cc pads are almost as dusty as the stock pads.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
05-16-2012, 02:42 PM | #9 |
310
Rep 4,002
We have advised on multiple previous posts that based on the photos provided
that your brake pads appear not to be making full contact with the rotor surface- additionally possible that piston clip is not fully engaged in the piston allowing drag and increased dust levels. Also the suggestion as to the possibility of paint or foreign material between the caliper mounting surfaces after removal and painting the calipers as a possible issue. While you did indicate that you like the CC pads for the way they work over stock for pedal modulation and increase to fade resistance, your repeat posting regarding dust are not in line with the majority of our customers that report well less than 50% dust compared with OE. We understand that not every vendor can satisfy every customer 100% of the time but we try - As you have over 1.5 years now with the product, perhaps a lesser performing pad with somewhat less dust could be a better solution for your situation. Please PM and we will again be happy to work with you directly
email: robert@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x21 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
05-16-2012, 03:21 PM | #10 |
102
Rep 1,903
Drives: e92 335i 6MT
Has anyone tried retrofitting the new OEM 2011+ pads on their cars? I understand they are much better dust wise.
05-17-2012, 04:50 PM | #11 | |
Rep 35
I went with akebono's this time around along with some slotted rotors from brakeperformance.com and installed/bedded them the same way as I did with the cool carbons. Completely silent, the way a street setup should be. Also, OP, unless you want to spend 2k for looks only, I'd save the money for a BBK and spend it on something else. Even for tracking your car, a BBK isn't really needed. |
05-18-2012, 08:51 AM | #12 | |
814
Rep 3,953
05-18-2012, 02:19 PM | #13 |
ahat
1036
Rep 2,592
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 |
05-20-2012, 08:30 PM | #14 |
38
Rep 119
I have Cool Carbons on my '07 335i coupe, and have had no issues with them for about 5K miles and 2 track days (Intermediate group). Brakes felt slightly better than OEM on the track, with no fade. Still on stock rotors, but replacing rotors soon for regular wear. Less dust than OEM.
05-20-2012, 08:52 PM | #15 |
86
Rep 1,262
I've got the TMS kit with Hawk HPS pads, Which made a huge difference dust wise.
Their kit is very complete and their discs are very high in quality.
Josh-
