BEP Billet Compressor Wheel Install & Results
05-15-2012, 10:35 PM | #1 |
19
Rep 264
So it all started with an email to turbokits.com and went from there. I inquired about the Bulls Eye Power(BatMoWheel) Compressor wheel, Since I was the guinea pig for this Jesse from TK proposed an offer I could not refuse. So we went back and forth with a bunch of emails and got everything settled and I went down to Turbokits.com in connecticut for my "Before" dyne session. The facility there is amazing, there are a ton of cars and projects there and they really know what there doing. Jesse was very accommodating and showed me the shop then we latched down the 335 and got ready for some pulls. My car has a jb3 on map 3 and a dci installed, and out of the 6 pulls the car made on average 320whp and 325wtq on a mustang dyno.
Car jacked up and ready. Then I removed the plastic under trays and the V brace. Then the oil was drained as well as the coolant. For manual cars you can drain it from the water pump which looks like a little turbo near the front intercooler. On AT cars you can remove the hose from the heat exchanger above the sway bar. If I need to explain how to drain the oil then I would suggest you don't try this. Next I had to drop the subframe so first I unbolted the passenger side engine mount. First unbolt the 2 ETorx bolts that connects the engine mount to the subframe and then the 4 Etorx bolts that connects the engine mount to the engine. Be sure to support the engine with a jack. While I was there I unbolted the steering rack so it could be moved around. Now that was dropped it gave me a little better access to the downpipes. So the o2 sensors were removed and I removed the 4 bolts connecting the downpipes to the mid pipes and then the v-band clamps. Smallest turbos I've ever seen And the Rebuild Begins. The exhaust housing/manifold is connected to the center section with a v-band clamp. The compressor housing is held together with a very stubborn snap ring. Stock Wheel BEP Billet Compressor Wheel Manifold/exhaust housing Ceramic coated Everything will be going back together tomorrow, And car will be re-dynoed on Saturday Last edited by M3Tuner44; 05-15-2012 at 10:40 PM.. |
05-15-2012, 10:39 PM | #2 |
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
Nice write-up.
05-15-2012, 10:40 PM | #3 |
11
Rep 399
seems like alot of work just to change out the wheel.. personally if i would tackle this i would install bigger turbos
very curious to see results though!
JB4 G5 ISO W/BMS FLASH, FBO, Walbro LPFP, Spec S2+ SMFW
05-15-2012, 10:45 PM | #4 |
19
Rep 264
Well I wanted to see the results and I don't have the budget for bigger turbos. This is the kind of job that once you've done it one time, you can definitely do it quicker the next time around.
05-15-2012, 10:50 PM | #6 |
177
Rep 6,631
The exhaust turbine is your bottleneck. Check your PMs.
E90 LCI N54 6AT
05-15-2012, 10:57 PM | #8 |
115
Rep 1,544
Drives: '22 i4 M50
Interesting. Wish you could just come over to Cali and install my turbos for me :P. Nice work by the way!
2022 i4 M50, Dravit Grey. fully loaded minus the carbon fiber bits and 20" wheel package
2007 E92 335i, 6MT, Sparking Graphite, ZPP, ZSP, Nav, Logic7 (Sold) |
05-15-2012, 10:58 PM | #9 |
19
Rep 264
05-15-2012, 11:06 PM | #11 |
177
Rep 6,631
They are already prebalanced, direct swap and replace. I have experience with this setup.
I will repeat, the stock turbine is your bottleneck. If it's possible to clip the stock turbine wheel, then you MIGHT gain a little power out of these things. Then you have to account for the wastegates. I don't mean to rain on your parade OP, but prepare to be disappointed. You will LOSE power. I showed you my results.
E90 LCI N54 6AT
05-15-2012, 11:09 PM | #12 | |
19
Rep 264
05-15-2012, 11:12 PM | #13 |
177
Rep 6,631
Anyone want the turbos the OP has? $260 shipped Preassembled center sections. Will make for a great rebuild option for those who don't want to spend $1000+ on new stock turbos.
E90 LCI N54 6AT
05-15-2012, 11:32 PM | #14 | |
Objects in the mirror are losing
105
Rep 1,133
Drives: 2007 BMW 335i E92 AW/CR 6MT
PERFORMANCE: JB4 G5 \ Backend Flash \ DCI \ BMS Downpipes \ CX FMIC \ ER Chargepipe \ Synapse BOV \ KW V2 \ Muffler Delete \ CDV \ ZHP Shifter \ Cyba Scoops FUN: M3 Front \ Mtech Rear \ JL 10W6 \ ModMyNav \ V1 Hardwired \ LUX H8 \ Gloss Black Trim \ Gloss Black Roof \ Cyba Quads \ Cyba Mtech Diffuser |
05-16-2012, 12:02 PM | #15 |
297
Rep 4,408
+1
-Critter
05-16-2012, 12:22 PM | #16 | |
Team Zissou
3065
Rep 10,197
That being said, just go with RB's, ASR, or a single turbo. When I needed new turbos quickly a few years ago none of the other options were available. |
05-16-2012, 01:58 PM | #17 |
177
Rep 6,631
We been there done that. If they were the same as stock I probably wouldn't have bothered swapping to RBs tho.
E90 LCI N54 6AT
05-16-2012, 02:05 PM | #18 |
207
Rep 422
Ceramic coating + exhaust turbine
I do aggre to others: The exhaust turbine is your bottleneck. Also you can play with clipped wheels, which is good for playing pressure.
Because of the restriction of the factory turbos (and hybrid turbos based on factory turbine house and manifold) I have decided to rebuilt my engine and built a completly new designed twins with custom made manifolds (we do not use factory turbos and factory manifolds) for my e92 335i. Project status: 45%. I will post some pics, once we ready. I encourage everybody to use high quality ceramic coating on different parts of the engine, on manifolds, on different parts of the turbos, even on downpipes and on exhaust pipes. M3Tuner44, i dont see wheather you have applied ceramic coating only external on manifolds and turbine house or also internal. Is much better and more efficency to apply ceramic coating external and internal to built "closed" heat shields. Laszlo |
05-16-2012, 02:09 PM | #19 |
387
Rep 1,571
These OEM turbos have double wall air gapped manifolds. Coatings are a waste of time for these special manifolds IMHO. But it looks cool, for a little bit anyway. Due to tight clearances and chances of flaking coatings I also wouldn't suggest doing internals even if you insist on following through with coatings.
05-16-2012, 02:10 PM | #20 |
Some dude
92
Rep 1,780
Thanks for confirming that. I thought the same thing the first time I held one in my hand. I thought that was pretty trick.
RRT
E92 335i/6MT with stuff and things |
