VRSF gaskets needed
05-15-2012, 01:06 PM | #1 |
85
Rep 1,356
VRSF gaskets needed
MY gaskets that connect from the downpipes to the exhaust on the left side is leaking. I replaced the bolts on it but still are leaking.
Could I buy some stock gaskets from BMW and use those or do I need to order some special ones? |
05-15-2012, 01:11 PM | #2 |
207
Rep 1,134
Drives: E90 335i LCI
No special ones needed. Go to local autozone or whatever is your local auto parts supplier and ask for exhaust gaskets
I can help with Coding in Vancouver. PM me
05-15-2012, 01:12 PM | #3 |
Rep 163
I don't see why the BMW ones won't work. Otherwise, I have heard good things about the AR gaskets.
05-15-2012, 01:51 PM | #5 |
65
Rep 554
Drives: E92 335i 6MT
If you can't find anything that works locally get a sheet of the mr gasket material from orileys and cut it to fit. I had a mangled gasket on the lude, no shops carried the size, so I just traced it out on there and cut it out.
05-15-2012, 03:05 PM | #8 |
85
Rep 1,356
let me ask you a question
are these the same http://www.verociousmotorsports.com/...-Flange-Gasket as http://www.ardesign.info/store/ar-de...asket-kit.html so if i order the ones from vericious, they would the same as long as i get the 2 1/2" |
05-15-2012, 03:38 PM | #9 |
202
Rep 1,950
Drives: 335i
05-15-2012, 04:07 PM | #10 |
85
Rep 1,356
sammy you in the fort worth area? we need to get a meet together man sometime instead of plano every time
and thanks! im trying to see if the ones at verocious are the same ones because that way i can just order an extra set for $10 really |
05-16-2012, 12:28 PM | #13 |
Rep 163
05-16-2012, 01:26 PM | #15 |
2095
Rep 43,350
All new downpipe orders from about 2 weeks on have been upgraded to the grade 12 bolts and will continue moving forward
I know some people had issues and that's enough for me to offer a higher quality option. We want to eliminate any potential un-awesomeness in our product if we can. |
05-16-2012, 01:33 PM | #16 | |
Rep 163
05-16-2012, 01:55 PM | #18 |
11
Rep 399
mine did the same thing.. i doubled up the gaskets until i got new oem ones
JB4 G5 ISO W/BMS FLASH, FBO, Walbro LPFP, Spec S2+ SMFW
05-16-2012, 01:56 PM | #19 |
11
Rep 399
i also needed new bolts and nuts.. the ones that came with mine were junk.. but i got the downpipes a few months ago.. i bought new stainless steel nuts and bolts locally.. not a big deal
