Boost Creep
05-15-2012, 09:15 AM | #1 |
2051
Rep 3,714
Boost Creep
I'm experiencing some boost creep/spikes on JB4 Map 5 with the 5/11 firmware that's supposed to be locked to 17 PSI max. Running a mix of 70% 93 pump gas and 30% E85 on an otherwise stock 335 6MT. Car runs great 90% of the time, did some logs in 3rd and Terry said everything looks good.
But in 4th and 5th when I'm rolling and boost is building I'm getting occasional spikes up to 18-20 PSI. I actually had one yesterday on a highway on ramp that triggered safety mode in the JB4 so that I couldn't boost over stock boost in any map until I restarted the car. I'm not getting any DSC or lights, no CEL, no limp mode so I wonder if it's a weak/faulty wastegate on my stock turbos @ 60K miles? Could it be a clutch slipping at high load? Also wondering how the car can boost past 17 psi if the firmware has that absolutely locked down? I don't seem to have this problem on map 1, holds to the correct boost levels. |
05-15-2012, 09:28 AM | #2 |
241
Rep 1,857
I had that same problem. I contacted Terry who had me set future use D to 2, which resolved the issue. You should contact him, he might have you do the same.
05-15-2012, 09:38 AM | #3 |
2051
Rep 3,714
What does the future use D adjust? Terry is out of office for a few days. Are you using the latest alpha firmware for E85 testing too?
05-15-2012, 12:33 PM | #4 |
241
Rep 1,857
05-15-2012, 01:16 PM | #7 |
17
Rep 305
hmm, i'm using future use d = 99 for the wastegate rattle fix, although its still present. Seems like it mightve helped a bit though.
This JB4 safety and stock boost on every map situation also happened to me at the end of a 2 hour drive, however, i had maybe 2 gals of 45/55 e85 left in the tank and had to fill up with 91 oct. By the time the tank was half (near the end of my 2 hr drive), i'm guessing the ethanol was flushed out mostly and the car probably creeped and reset into stock mode after seeing the change in fuel and timing, even though I switched to map 2. Refilled with 5 gals e85 and restarted the next day and its pulling like a slingshot again. So in my case i'm pretty sure it was from running out of e85. Let's see if this happens again while there's still plenty e85 in the mix. |
05-15-2012, 01:28 PM | #8 | |
2051
Rep 3,714
05-15-2012, 01:28 PM | #9 |
Joint Chiefs of Staff
4918
Rep 115,980
With alpha firmware you will need to contact BMS for help. If you start entering random settings without their direction you may damage your car. If you are unable to wait for BMS to get back to you then switch back to non-alpha firmware.
Mike |
05-15-2012, 01:37 PM | #10 | |
2051
Rep 3,714
Can you even run non alpha firmware with E85 in the tank? |
05-15-2012, 01:48 PM | #11 | |
4918
Rep 115,980
Bottom line is if you are running alpha firmware you should only be communicating with BMS on it. If you are unable to follow those rules you should be running the 3/25 production firmware. Mike |
05-15-2012, 02:30 PM | #12 | |
2051
Rep 3,714
