RB Rotors - Brake pads?
05-13-2012, 11:30 AM | #1 |
125
Rep 8,745
So I got myself those beautiful rotors at all 4 corners with Porterfield R4 S pads. I just had a track day with 7 x 20 min sessions at LCMT. Much more consistent braking than the OEM rotors + Cool Carbon pads.
Only thing, I have used over 50% of the front pads. The rears roughly 1/3. I also noticed metal filings sticking to the calipers. Looks like the slots are chumping off the pads. Any thoughts? Maybe harder pad compound for longer track life? Otherwise 2-day events will require a new set of pads each time. Is track only pads the solution for track and changing to softer material for street?
SB, Terra, 6MT. Only a few mods here and there.....nothing extreme!
05-13-2012, 11:53 AM | #2 | |
108
Rep 1,973
Drives: 2009 e92 MR "Civic" ///M3
Carbotechs are easier on rotors, but wear faster, it's a trade off on what's more expensive to replace. Hawk DTC are very aggressive on rotors, also last a bit longer pad wise, but performance decreases as the pad gets thinner. PFC01 are great, or the 08s for their endurance compound, which lasts a long time. The Pagids and Endless are also endurance based compounds but very expensive as well. I've used Hawks, and are now using Carbotech XP16/12 Front/Rear, they perform really well. May try the Pagid RS29s after the Carbotechs are done just to compare. EDIT: I keep a set of front floating rotors just for the track, and always switch out pads street/track for the events on all four corners.
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
05-14-2012, 06:51 PM | #3 |
1821
Rep 5,337
My Cobalt XR3s lasted 1.5 seasons (about 15 days) on RB rotors, and the DTC-60s are looking like they'll last at least 2 full seasons (20 days). It's not the rotors. It's the pad. The R4 S is far closer to the Cool Carbon than it is to a full track pad.
Granted my car is about 300 lbs lighter.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
05-14-2012, 07:01 PM | #4 | |
125
Rep 8,745
05-23-2012, 11:07 PM | #5 |
Oldie Newbie
Rep 134
I found out the hard way Carbotech pads (XP-10) are not compatible with RB rotors. Uneven deposits on rotor. See RB's forum for details.
I have all 4 corners PFC-08 pads new in the box. Should be compatible with RB according to my research. PM me if interested.
2007 335 coupe, M3 suspension, Koni Yellows, Ground Control camber plates, RB rotors, Kosei K-1 17" with 255 x 40 square Direzzas or BFG R1
06-04-2012, 08:48 PM | #6 |
Rep 28
I have no association with RB but I thought it important to provide technical information regarding Bro's comments above. Based on his conclusion that the rotors were the issue - which would be extremely unusual in my extensive track experience, I went to the RB website to review the "comments in the forums".
I was not surprised to find exactly what I suspected - some folks did not understand that pad transfer is the result of the pads being operated outside the proper temp range for the pad and thus the pad smears and adheres to the rotor. Additional brake cooling and or changing to a proper heat range pad can prevent the over-heating of the pad material and transfer to the rotor. This has also been the case with OEM BMW and aftermarket rotors when the incorrect pads for the conditions are used. In Pro racing many teams change pad compounds, rotors and brake duct cooling for each track and ambient temps. http://forums.racingbrake.com/showthread.php?t=73 |
02-13-2013, 06:32 PM | #8 |
125
Rep 8,745
Update: Both HP+ and PFC 08 seem to work well with the rotors, with minimal pad wear. The Porterfield R4 S was just too soft for track driving.
02-23-2013, 06:56 AM | #10 |
51
Rep 457
I'm glad to hear that the PFC 08s work well. Did you have to order the rotors/PFC pads from the states, or is there a Canadian vendor?
02-23-2013, 06:36 PM | #11 | |
125
Rep 8,745
For the PFC 08, those do not come with metal brackets behind the pad. So the pad is loose and may be very noisy for city driving. My mechanic fabbed me a little metal wedge to eliminate the pad play and hence got rid of the noise...
03-01-2013, 01:30 AM | #12 | |
Supreme Allied Commander
3868
Rep 54,426
Drives: F80 M3
03-01-2013, 07:40 PM | #13 | |
125
Rep 8,745
How are you Harold? You remember I got the RB rotors from you, did you sell a few of those RB aluminum calipers? I think the only issue I had with them was pad choices, do you get PFC 08 in that pad shape, I think 1149 or something? Thanks
03-01-2013, 09:43 PM | #14 | |
3868
Rep 54,426
Drives: F80 M3
Harold |
