Rattling coming from exhaustm
05-13-2012, 08:21 AM | #1 |
Rep 38
I know this has been discussed in great detail but I can't seem to peg what is going on with this rattling sound that seems to be coming from my exhaust at the rear of the car. I have a 2008 335i sedan with 65K miles. If I am in neutral and hit the accelerator there is a rattling sound that I am certain is coming from the rear of the car around the exhaust. It also happens when I downshift and the rpm's rise. Wastegate rattle? Muffler? I have a stage 1 tune and there is no lack of power and my performance is not affected at all....just that annoying rattling sound...any ideas? Thanks in advance!
05-13-2012, 08:35 AM | #2 |
202
Rep 1,950
Drives: 335i
05-13-2012, 08:41 AM | #3 |
196
Rep 6,136
Sounds like a wastegate rattle to me.
Just to check to see if it is something minor (the exhaust flapper), with your engine off, follow this tutorial: http://www.e90post.com/forums/showthread.php?t=80661 Then start it up, revv it (when your engine is warm of course) and see if it still rattles. If it does, you probably have a wastegate rattle. If it dousn't, then just leave it unplugged, you will have a slightly louder exhaust. |
05-13-2012, 08:42 AM | #4 | |
Rep 38
05-13-2012, 10:33 AM | #6 |
116
Rep 1,346
Drives: 2011 E92 335 M-Sport
older 335i versions don't seem to have this connecting rod for the rear mufflers. Not sure if this is a coupe thing or an LCI thing, but it's something that I've noticed when looking at the exhausts.
LCI
05-13-2012, 10:38 AM | #7 |
1435
Rep 4,724
It's the westgate rattle. Under the Class action lawsuit with BMW, they will fix it for free up to I believe 70k miles. Take it in ASAP, and get it fixed! This is a common problem on 07 and 08 build N54 engines. In the 09 and later models they put in larger westgates to fix this problem.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
05-13-2012, 01:10 PM | #8 |
41
Rep 1,089
Is there a reference to refer to the bmw dealership? Because I took my 08 335i in 3 times for a rattle, but they kept checking the exhaust and have fixed nothing and said the rattle noise is "normal". If I went in for a "wastegate rattle" under cpo warrenty, will it show this lawsuit on their computer and check it and replace the wastegates?
05-13-2012, 04:30 PM | #9 | |
1435
Rep 4,724
05-13-2012, 06:38 PM | #10 | |
Rep 38
05-15-2012, 10:00 AM | #11 | |
1435
Rep 4,724
