Spark plugs....
05-12-2012, 12:36 PM | #1 |
7
Rep 85
Spark plugs....
Its time to change my plugs so what type of plugs does the n54 like. I also understand that i need a special tool to do the plugs? Whatd it called, where to get it, an how much ... thanks guys always good info here!.. .. 07 E92, jb4 dci, fab speed dp
05-12-2012, 12:58 PM | #3 |
70
Rep 2,197
N54tuning.com sells the plugs and socket required to change them.
Here's a DIY to help you out: http://www.1addicts.com/forums/showthread.php?t=602804 |
05-12-2012, 05:00 PM | #4 |
Retired e90post Member
135
Rep 3,038
I get my plugs from ecstuning.com and I believe they also have the tool for like $15 or so. Have fun
05-12-2012, 05:03 PM | #5 |
161
Rep 7,377
No need for a thread.. Just search next time.......
05-12-2012, 07:11 PM | #7 |
112
Rep 2,856
Drives: 2011 335is E93
Try NGK plugs too...they run colder than stock and from my understanding that's always a good thing for turbo cars
05-12-2012, 08:14 PM | #8 |
212
Rep 1,071
Splurge for the OE spark plugs from a BMW dealership, they’re the best plugs for our cars. The OE plugs don't seem to cause rough idling like the Bosch OEM plugs.
A special 12-point thin walled spark plug socket is essential for changing the plugs on an N54 engine. Don’t even think about doing the job without one. Using a rubber hose is a good technique to prevent cross threading the steel spark plug threads into the engine's aluminum cylinder head threads. Unlike a socket, the rubber hose technique prevents a mechanic from applying sufficient torque to damage the cylinder head threads if the spark plug threads aren't lined up correctly. I’m happy with these special tools that I purchased from Turner Motorsports: TMS P/N 83300495560, N52/N54 Spark Plug Socket for 2006+ BMW 6 Cylinder Engines, 1 @ $52.95 each (made in Germany). TMS P/N 83300496065, N52/N54 Spark Plug Install Tool, 1 @ $17.95 each (made in France).
05-13-2012, 12:14 AM | #10 |
149
Rep 3,552
go with oem.
here is what i did, ebay- x 6 http://www.ebay.com/itm/260889897412...ht_1036wt_1079 ebay- x1 http://www.ebay.com/itm/170830622234...84.m1497.l2649 less then 85 for both! easy to change out yourself. and spark plug tool is great! |
05-13-2012, 01:13 AM | #11 |
12
Rep 656
Bosch lists ZGR6STE2 as a plug for the N54. (I got a set of these and then a set of OEM ones when I purchased the performance power kit. They look exactly the same except for some "wording" on the ceramic insulator. I've posted pictures of the two in the past...) I use shopzilla.com, bizrate.com, nextag.com, and pricegrabber.com to search whenever I'm looking for something. Lots of hits come up and they rate the sellers...
05-13-2012, 03:40 AM | #12 |
39
Rep 315
Factory / OE plugs and get the damn tool. Job can't be done without it. I recently purchased stuff from ECS Tuning and was very happy with my experience as a customer there.
05-14-2012, 10:30 AM | #13 |
Boosty
55
Rep 325
Are colder plugs better for this engine? Or are the oem cold plugs?
'08 335i AT Alpina Flash~Rob Beck Turbos~Full kittyless exhaust~DCI~5" Intercooler~Chargepipe BOV~BMS meth kit
05-14-2012, 04:01 PM | #14 |
Jewbacca
10
Rep 219
I used the Bosch aftermarket ones and an old tool with no magnet from BMS. I used a pen magnet to pull them out. Works just fine.
2007 E92 335i - Retired
2011 E92 6MT 335is - JB4, Stett CP, Synapse BOV, Wagner FMIC, BMS OCC, CDV mod, AFE DCI, Cyba Scoops, BMS Clutch Stop, P3Cars v2.1 vent gauge, LED side markers. |
05-16-2012, 06:33 PM | #17 |
15
Rep 290
question
Would have been a waste to replace theses plugs right?
Also the top white ceramic part looked fine / completely white.. Last edited by WickedB; 08-20-2012 at 09:35 PM.. |
05-16-2012, 07:39 PM | #19 |
15
Rep 290
05-17-2012, 07:35 AM | #21 |
55
Rep 1,690
Another thing to look at is the gap. Functionally the spark could be fine. But over time the prongs will erode due to use which widens the gap. The DME can only compensate so much before you will start to get misfires.
06-01-2012, 12:53 PM | #22 |
17
Rep 476
So I'm at 54k miles now and I'm about to change my plugs soon. I will be getting 6 BOSCH plugs and either the BMS or Schwaben socket tool. What else would I need? I read about people talking about some extension?
'08 E92 335Xi - Premium, Cold and Sports Packages
JB4 // AFE DCI // Matte Black Grills // MTEC Angel Eyes // CF Mirror Covers // Forgestar F14's |
