Does A+B=C or just B
05-09-2012, 05:52 PM | #1 |
Rep 10
When your speaker wire goes from your head unit to the high level output of your amp to your speaker, do all the watts stack. For example, your head unit is 25 watts and your amp is 50 watts, does that mean the power to your speaker is 75 watts? Or is it only 50? If it is only 50, why is that?
05-09-2012, 07:20 PM | #3 |
1917
Rep 13,108
Whatever comes out of the final stage is it.
If the amp channel that you connect to the speaker is 50 watts that's what you get. Which is why it is preferable to have preamp signals as Inputs for your amp. Why because the A is not connected to your speaker. And if you did connect A to the speaker there would be conflict between the two channels feeding the speaker. If you actually want to understand it you need to study how amplifiers work. |
05-09-2012, 08:40 PM | #4 |
281
Rep 4,121
Amps put put volts not watts in reality. If you input more volts than that for which an amp was designed, the signal will be clipped, then amplified. THAT is bad stuff
05-09-2012, 09:20 PM | #5 |
1917
Rep 13,108
Yes they put out volts but there rated in watts
which is a combination of current times volts. Last edited by ctuna; 05-09-2012 at 11:42 PM.. |
05-09-2012, 10:17 PM | #6 | |
Resident Car Audio Guru
7
Rep 597
obviously, I'm dumbing it down a bit for you, but that's how we measure power, in watts, from an amplifier. it's also why we call it a power amplifier. Volts is just one measurement from an amplifier.
05-10-2012, 09:31 PM | #8 | |
688
Rep 6,845
Drives: 2018 Audi RS5 coupe
There was no need to get all AMPed up Stop being so resistant to change
05-10-2012, 10:42 PM | #9 |
8
Rep 186
05-11-2012, 12:14 AM | #10 |
7
Rep 597
I think the problem is that I'm just a dick. But I'm aware of the problem, so there's that.
05-11-2012, 08:37 AM | #11 |
223
Rep 5,120
05-11-2012, 09:15 AM | #12 | ||
281
Rep 4,121
Im aware of all that thank you, |
05-11-2012, 09:34 AM | #13 |
7
Rep 597
Voltage, Current, Resistance, and Power ALL exist simultaneously in ANY electrical circuit. One cannot have a circuit without all of them.
