what to do next ? 12.8@114mph
05-05-2012, 10:35 PM | #1 |
12
Rep 232
hi guys, i would like some suggestion for the next easiest mod for more power
here s my set up for the drag strip: -94 oct pump gas (a quarter full tank) -bigger fmic -catless dp -catless mid pipe -stock air box ( no air filter ... just for the pull ) -cobb v301 stage 2 agressive map ( 15 psi ) -hossier drag radial 275 40 17 -oil temp --- 80-90 i don t want to use meth... i have access to 98oct race gas and 114oct (unleaded) thanks
2007 335i coupe AT-- I80AS--FBO -stock turbos--COBB v402 beta stage 2 + ATR-- NITTO'S 275-40-17 NT05R --- 12.025 @ 120 mph -- full weight
05-05-2012, 10:46 PM | #2 |
149
Rep 3,552
your traps are good, your time is a little slow. i ran 12.9@108 with a 2.0 60' with intake and tune.
please post time slips. how is your 60' you should be low 12's. id go with DCI or weight reduction. Unless you want upgraded turbos. |
05-05-2012, 10:49 PM | #3 |
Real Car Enthusiast
288
Rep 2,082
Race gas won't really help you with a flash tune unless you have the race map. I would definately get an intake. You could try to ask Cobb for the Beta race map, but I'm sure hundreds others have already tried this with no luck.
05-05-2012, 11:34 PM | #4 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
Stage 2 or Stage 2+FMIC?
The i8 needs a V8 amirite?
05-06-2012, 12:16 AM | #6 |
153
Rep 3,730
More practice.....
oh and... LSD / Suspension / M3 bits
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
05-06-2012, 06:22 AM | #7 |
24
Rep 857
Drives: 2008 Montego Blue 335i
You are trapping better than that time . Slow 60' maybe. Tires?
05-06-2012, 06:57 AM | #8 |
12
Rep 232
yes stage 2 plus fmic..its an auto ,i launch it at 1500rpm,,,,i know maybe i can go harder on the launching
-60ft ---- 2.24 -330ft---- 5.704 -660ft---- 8.46 -Et ---- 12.812
05-06-2012, 06:59 AM | #9 |
12
Rep 232
that would be great...maybe the boost could be raise a bit like 16-17 psi on race gas maps
05-06-2012, 07:14 AM | #10 |
12
Rep 232
yeah m3 lsd would be a good thing to do in the future for sure
05-06-2012, 07:18 AM | #11 |
24
Rep 857
I get 2.1s with my car. No bolt on's. Just a mild tune. You rape my trap speed. Iv only hit 106.8mph. If you got the 60' down a notch or two. Would see a big increase.
05-06-2012, 07:37 AM | #12 |
31
Rep 372
You can lose some weight, YOU! not the car, your car will be happy. Recently I saw a HUGE lady (280-300lbs) getting in 3 series. I stopped for good 2 minutes to watch her get in. She had to squeeze her belly away from steering wheel to fit in .
05-06-2012, 07:48 AM | #13 |
ElevenPointFive
326
Rep 2,450
Run your drag radials at 20psi of pressure and launch that car harder. 2.4 60 is unforgivable with drag radials on.
2008 E90 335xi - N54 Daily Driver
MHD Stage 2+ ~ CPE DPs ~ BMS Intake ~ AMS FMIC |
05-06-2012, 08:13 AM | #14 |
149
Rep 3,552
2.24.... is your problem.
how is your launching technique? 2.24 can be pulled off with ease with stock continentals. with Drags you should be cutting AT LEAST 1.9 or 1.8 no lSD. are you launching first or 2nd gear? |
05-06-2012, 08:21 AM | #15 |
3431
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
No question - LSD.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
05-06-2012, 08:36 AM | #16 |
24
Rep 857
Didnt see he had 275 drags.. My hankook 255s shouldnt have a better 60'
05-06-2012, 08:54 AM | #17 |
69
Rep 868
get your 60' ft down to 2.0 from your 2.2...... 2 tenths off sixty foot = 4 tenths at the 1/4 time assuming everything else is the same.
My jb4 max boost 13.4 psi(it needed fixing) 19" street tires, a/t I ran a 12.3 @ 114..... I bet u get your 60' ft time down you can do the same
JB4 G5 ISO , AR DP's, DO Meth kit Trunk Mount, ETS 5" Intercooler, M6 Rims, ER Charge Pipe, Fordged DV's, MMp relocated inlets, Ebay 4" chrome Tips, Lux Angel Eyes **********11.910 @ 117.09***1.851 60'********** |
05-06-2012, 09:01 AM | #18 |
12
Rep 232
I launch in first gear ( all etc off ),,,hold the brake ...gas at 1500rpm ....pedal to the metal !!!...i saw people doing brakeboost at 3500rpm ????..this must be so bad for the AT.im just not wiling to do it
05-06-2012, 10:54 AM | #19 |
7
Rep 151
lmfao should of took a vid
05-06-2012, 12:58 PM | #20 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
I'm confused that it's only hitting 15 psi. I've seen my Cobb report 17 psi on Stage 2+ Sport.
05-06-2012, 02:02 PM | #21 |
12
Rep 232
maybe i have a boost leak but i doubt ...on my cobb it peak at 15.6 psi...but stabilize at 15psi on stage 2 aggresive plus fmic
05-06-2012, 03:18 PM | #22 |
313
Rep 3,262
I learned that more power is not always the answer. Without a good 60ft of 1.9-1.7 you have no chance for great results. The keys to a good 60ft are skill, burnout before race and proper tire pressure (needless to say I kind of lack at all of these ).
