Engine coolant change interval?
05-05-2012, 01:49 PM | #1 |
247
Rep 2,567
Hi guys,
I was curious as to what the coolant interval change is for these cars? I have a 07 e92 335, with about 26,xxx miles. Bought in Feb of 2008. Coolant hasn't been changed yet. Should I do an engine coolant flush/fill?
07 e92 335i - Retired
18 F80 M3CS - Retired 21 G20 330i M-Sport - Current |
05-05-2012, 03:04 PM | #2 |
1837
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
No. BMW considers coolant as "lifetime fill", no real need to change it unless it becomes contaminated. Brake fluid, yes. Transmission/rear axle - depends on your preference, although I changed mine at about 35K miles.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
05-05-2012, 05:48 PM | #5 |
212
Rep 1,071
BMW's recommended coolant change interval used to be every two years. Since 2004 BMW claims the engine coolant is a "lifetime fill". I sort of compromise by changing the "lifetime fill" engine coolant every three years or 30,000 miles. There's no scientific reason for that interval, I just chose it because it sounds more reasonable to me than never changing it (until your water pump, thermostat, etc. needs replacement). I use a 50/50 mix of BMW antifreeze and distilled water. IMO, it's not worth risking corroding the engine's aluminum block and head to save a few dollars by using cheap antifreeze and tap water.
05-05-2012, 05:48 PM | #6 |
164
Rep 2,556
Did a drain and fill at 40k per my indie
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
05-05-2012, 06:22 PM | #7 |
247
Rep 2,567
I'm definitely going to use BMW OEM coolant. Do I mix it with water or no?
08-18-2012, 08:40 PM | #9 |
146
Rep 942
Resurrecting this post. my '07 with 45k miles is showing high Electrolysis levels today. Checking it from the coolant resv to the ground jump lug. .3-.4v.
'07 335i Sedan, base pkg, 6spd Manual, Procede 3 V5 w/NLS, Macht Schnell Downpipes, 18" Staggered 313's w/Conti DWS's, OS Giken TCD LSD, VAC Street Diff Cover, Dinan Oil Cooler, Dinan Intercooler, Akebono Euro Pads, CDV Removed, Black BMW Grilles, Interior & Exterior white LED lighting, LUX Angel Eyes, Debadged, Blend V1 mount, Llumar ATR Tint.
