Fault codes!!!
05-05-2012, 01:14 PM | #1 |
112
Rep 2,621
Fault codes!!!
Had a few problems for a few months with misfires and limp modes being triggered. No codes however, until today got the following:
29F4 Catalytic converter conversion 29F5 Catalytic converter conversion 2 2D18 manipulation cover, maximum air mass 2F71 E-box-fan, input signal 3100 low boost mode engaged -- CEL displayed 0000 Failure location not implemented Cat codes are from the Catless DPs eBox fan has been there a while but sounds like not a big deal.. So 2D18? Could this be a MAF/MAP sensor having a hissy fit? Any helps is much appreciated...
Car: e91 330d with Viezu map
Gone but not forgotten: 2010 Jaguar XFR (Cat-back exhaust, pulley, intake mods and map), Highly Modified E90 335i LCI M Sport Manual (circa 480BHP/500lb ft) |
05-05-2012, 02:44 PM | #3 |
26
Rep 660
i got 29F4 Catalytic converter conversion 1 and 29F5 Catalytic converter conversion 2 too,
is that got to do with the O2?
PROcede REV3+OpenFlash "Custom DynoTune" //Vishnu PWM Meth kit//AIS Meth Tank//18" Forgestar F14//BridgeStone RE11//WaveTrac LSD n M3 Bushing//
KW V3 Coilovers//ETS 6.25" FMIC//MS Ceramic Coated 3" DPs//aFe DCI//M3 style body kits//HPF GEN2 Exhaust//Performance CF Trunk Lip//FFTEC walbro 450 inline pump kit// |
05-05-2012, 03:07 PM | #4 |
40
Rep 522
- O2 cat codes
- Tuner code - ECU fan issue (maybe your USB cable is blocking the fan and AFAIK there two holes you can pop the cable through. The top one doesn't block the fan) - LIMP mode with low boost. Typically caused by another code. The 0000 code looks odd. Did you try to see what INPA says? Any shadow codes? |
05-05-2012, 04:15 PM | #5 |
112
Rep 2,621
Haven't managed to get Inpa working yet!!
They are the only codes raised by jb4. I don't have a BT cable either! I should mention that this is on map zero..
