Easy Question, Need fast response: How do I use the Proceed to clear codes
05-04-2012, 10:44 AM | #1 |
Rep 97
I'm heading into service, and don't see anywhere in the logging menu to actually reset codes. How do I just clear them before I remove the unit.
05-04-2012, 10:50 AM | #2 |
The bigger they are...
18
Rep 264
With the ignition on but the engine NOT running, push the gas pedal to the floor, release, and push again. Crank the car and all codes should be gone. You might also want to put the car on MAP 0 while it is at the dealership.
Tom Williams BMW Service Advisor
'07 335i Sport 219M Wheels, MMW CF Lip, Shadowline Taillights, Vishnu Procede, BMS DCI, BMS OCC, Aasco LW Flywheel, South Bend Clutch, Turner 90mm Studs, Stoptech pads rotors and lines, BMS LED Tag Lights, BMS Clutch Stop, BMS Clutch Non-Delay Valve, ACS Style Rear Glass Spoiler |
