FBO Build Thread + Dyno
05-03-2012, 05:47 PM | #1 |
18
Rep 201
I attended the EFI Logics Dyno Day last weekend in Bethel, CT to get a baseline HP/TQ reading for my 2008 335XI coupe 6MT w/48K miles.
Dyno Run #1 - DCI + Cobb Stg 1 Agressive (93 Octane) - 278HP/308TQ Dyno Run #2 - Baseline w/DCI (93 Octane) - 254HP/257TQ Dyno Run #3 - DCI + Cobb Stg 1 Agressive (93 Octane) - 284HP/311TQ The only problem I ran into on the dyno was on the first pass. Chris from EFI said I threw a code for a boost leak. I've never encountered this on the street, so I wasn't worried and just had him delete the code. We didn't have any problems on the 2nd or 3rd runs. Chris mentioned that all stock XI N54's seem to dyno in the 250HP range on the Mustang dyno. I've also done a baseline 1/4 mile run (completely stock). I'll be returning w/FBO in June for another few passes. 60' 1.925 330 5.596 1/8 8.669 MPH 80.01 1000 11.296 1/4 13.506 MPH 102.13 Now that I have a solid baseline, I've done some shopping! Today, I ordered: CP-E 3" Catless Downpipes ER Competition FMIC w/CF Shroud ER Chargepipe Forge DV BMS OCC I'll be installing all of the above in the next 2 weeks, reflashing my ecu w/the Cobb Stage 2 + FMIC Aggressive Map, and heading back to the EFI Logics dyno. So stay tuned. I'm up in the air about doing the intake valve cleaning prior to dyno'ing, b/c I'm not sure if my engine has any tell-tale signs that it needs it. I've had 3 injectors and all the spark plugs replaced by the dealership recently. Is there any preventative maintenance that I should be doing before installing the rest of these bolt ons? Thanks! -Dan- Last edited by Danny271; 05-03-2012 at 07:22 PM.. |
05-03-2012, 07:08 PM | #2 |
Rep 140
Nice XI numbers
2008 BMW 335xi MT e90
JB4 G5, WW meth kit, turbonetics intercooler, DCI, UR catted dp's, UR catback, koni yellow + H&R springs, Rieger front bumper, Avant Garde 19" wheels |
05-03-2012, 07:18 PM | #3 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
You're doing it right
Are you planning on changing the intake, though?
The i8 needs a V8 amirite?
05-03-2012, 07:31 PM | #4 |
18
Rep 201
Thanks! I was originally shocked when I saw 254whp for the baseline run, but was reassured that it was quite a normal # for that specific type of dyno. I keep reading that depending on how the dyno is loaded, Mustang dyno's read between 11-12% lower than a typical Dynojet.
That puts my whp at right around 280whp on a Dynojet. Thanks! I currently have a BMS Dual Cone Intake. I've read that this is pretty standard for FBO cars. Although, I have been checking out the Stett CAI a lot lately... |
05-03-2012, 07:58 PM | #5 |
208
Rep 2,558
Congrats on the new mods... here's what you have to look forward to
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife |
05-03-2012, 08:22 PM | #6 |
115
Rep 3,345
glad ill be a part of this. literally....
Brentuning Cobb AP pro tune -IG: @beemeraddict 2010 335i zmp fbo, 465/513 E60 mix |
05-03-2012, 09:08 PM | #7 |
18
Rep 201
05-03-2012, 09:11 PM | #8 |
18
Rep 201
I would be ecstatic if I dyno w/your #'s!
05-04-2012, 03:47 PM | #10 | |
Aficionado of All Things Vroom
171
Rep 1,213
Plugs/Injectors would be the only things that come to mind and it looks like you took care of that already. If you're not getting a rough idle/stumbling RPMs the intake valve cleaning is really up to you. It's not a bad idea (as far as preventative maintenance is concerned), and i'm sure you've seen tons of threads about how much better people say their motors run after doing it. BMW is picky about warrantying the process though, and it can be a very expensive endeavor out of pocket if done at a dealer. My feeling is (and I'm at 33k on my 335) I'd rather have the blasting done earlier rather than later, even if it means I have to do it a second time down the road. I would hate to unknowingly sacrifice performance from all that crap building up!
Current: 2020 F97 X3M Competition
Retired: '18 6MT AW F30 340x Drive | '15 6MT F80 M3| '11 AW DCT E92 M3| '09 6MT AW E90 335i| 08' 6MT E92 328xi |
