BMS OCC question
05-03-2012, 02:57 PM | #1 |
Rep 61
BMS OCC question
So I've had my OCC for about 3 months. I was changing my spark plugs the other day and I went and tried to empty my OCC.
I found zero oil in it. I checked all the connections and the flow direction. All good. I am using Mobil1 Extended Performance Full Synthetic Oil. Does this have anything to do with this? Is my OCC not working right? I also have an oil cooler if that matters. |
05-03-2012, 03:57 PM | #3 |
90
Rep 632
The other day, I was installing my charge pipe. The oil is all over the charge pipe and intercooler pipe...
It's really scary... I will get an OCC next week or so. |
05-03-2012, 04:01 PM | #4 |
68
Rep 942
Same, imagine it fouling up the MAP sensor so it can't get 100% accurate readings..trying to source one myself.
05-03-2012, 11:57 PM | #5 | |
Rep 61
05-24-2012, 09:39 AM | #6 |
100
Rep 1,384
i installed my bms occ last weekend, and i dont know if this is a placebo effect or not, but i feel like my car doesnt have as much boost as it did before i installed the occ.. i feel like one of the pipes going to the occ could might be getting pressed due to the engine cover.. any way this can affect the engine performance?
05-24-2012, 10:11 AM | #7 |
Rep 54
I cannot speak to the loss of power but I just switched from my "homemade" catch can to BMS. My original one didn't have any oil in it after 3 months but I know it was functioning because I used clear lines and could see the light oily coating on them. Oily air was definately passing through it just wasn't very much.
I count that as a good thing but am glad to have the OCC for piece of mind. On a side note, my wifes 07 GTI now has my original OCC on it and I drain that every 2 months! Collects a nice dixie cup of crappy oil/water. |
05-24-2012, 10:20 AM | #8 | |
Joint Chiefs of Staff
4918
Rep 115,980
Glad you guys are enjoying the BMS OCC.. Its becoming the standard in terms of OCC on this platform. Mike |
05-24-2012, 10:24 AM | #9 | |
79
Rep 2,396
Drives: '08 E90 335i
If your car is out of warranty and you don't mind, you can cut the very back of the engine cover off -- The BMS install shows a picture of what I'm talking about @ the end http://burgertuning.com/instructions/occ_install.pdf |
05-24-2012, 10:52 AM | #10 | |
100
Rep 1,384
05-24-2012, 10:58 AM | #11 | |
79
Rep 2,396
Option A: IF you're planning on trading the car into a BMW dealer/not keeping it, I wouldn't cut it up. Option B: IF you're keeping it, then they shouldn't give you any trouble -- cutting the engine cover is going to have no negative impact on the performance/reliability of the car. Option C: (this is what I'd do 1st) See if there's a BMW aftermarket garage/mechanic who's done this install before near you, maybe they can recommend different tubing OR move some things around so it sits flush. |
05-24-2012, 11:32 AM | #14 |
56
Rep 1,464
Drives: 2009 BMW 335xi
I think the bms occ is a great option. The piece itself is pretty impressive and it is easy to install and it works. I installed mine and immediately went on a 1,000 mile road trip. It may have been a placebo or maybe riding with the cruise seton 80 for hours but the car felt smoother and stronger to me.
I recently changed my oil and so I checked the occ and there was only a little residue inside. It had only been 3000 miles so I did not expect large quantities. The only thing I have noticed is that I get a faint wooshing sound at part throttle from 3k rpms on up that I did not have before. I assume that is is the sound of the air moving through the lengthened hoses and occ. The only other thing it could be is if I have a leak at one of the connections but I have no codes or performance decrease. Has anyone else noticed anything like this? |
