Intercooler or METH?
05-03-2012, 12:06 PM | #1 |
107
Rep 559
Hello,
I am thinking about buying a new mod soon. Current list JB3 (will upgrade to 4 soon) Intake catless downpipes Miltek exhaust I am debating between the BIG TOM intercooler or Meth kit. I have no knowledge about Meth kits at all. I just hear you guys talking so much about it. What do you guys suggest? Big Tom IC or Meth kit? and which is a good meth kit, which comes with EVERYTHING a noob needs? OR would you guys suggest a different mod? Like a Oil catch can or upgrade the oil cooler? etc.
08 E92 335i AW Coral Red 6MT Fully Loaded|AA DP|BMS DCI|JB4 G5|Milltek full exhaust|SSK|Stett CP|Tial bov|Tinted window|HID Fogs|M3 Front|Mtech Rear|VMR V710|ACS pedals|V1 hardwired|BMW Performance Parts-Shift knob-Boot-E-Brake-SteeringWheel|CF Parts CSL trunk-V35 Hood-ACS roofspoiler|Red Pre-LCIs|Tow hook Plate|Clutch Stop|
05-03-2012, 02:19 PM | #2 |
196
Rep 2,669
Email me, I have a HFS-4 Group buy kinda thing going on.
****************************** I also can help you with buying a Big Tom style FMIC (Like in my sig) |
05-03-2012, 02:40 PM | #3 |
Joint Chiefs of Staff
4918
Rep 115,980
I would upgrade to the JB4 first and then get one of the FSB kits (either trunk mount or WW depending on your preference) They incorporate very well with the JB4.
The advice I always give is to get the Meth Kit your tuner supports. Mike |
05-03-2012, 04:14 PM | #6 |
153
Rep 3,730
FMIC = Passive
Meth = Active Depends if you wan't something working all the time, or just when activated. That being said, when meth is spraying, it will lower your IAT's more than a FMIC and CAI combined. If you can swing it, get both. If bought used, you can have them both for under $1,000.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
05-03-2012, 04:27 PM | #7 |
170
Rep 803
Are there any downsides to meth?
All I hear about is how it actively cools your engine. I always hear pros, not cons. For some reason I was under the impression that it strains your engine.
black/black/black e92 loaded
Instagram: _eamon_ |
05-03-2012, 04:30 PM | #8 |
39
Rep 1,154
I would go with e FMIC. I have ran meth on my past 2 cars and won't ever run it again. I didn't blow an engine or have any damages, it is just a PITA to keep the tank full and buy meth. It becomes an inconvenience.
2016 340i xdrive
2009 335i |
05-03-2012, 04:34 PM | #9 | |
153
Rep 3,730
Running a WIJ system without fails safes could damage the engine. If you are spraying and one second it goes dry or clogged, the ECU might not be able to pull timing fast enough and you could damage a cylinder.
05-03-2012, 04:45 PM | #10 | |
dat boost doe
238
Rep 1,823
i just conceded to have a professional install my kit, because this seems a bit outside my safety zone.
05-03-2012, 07:27 PM | #13 |
866
Rep 5,451
If it was a good bolt on intercooler or meth it would be a harder decision, if you only have 300 bucks, get the meth and then save up for a decent bolt on intercooler.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
05-04-2012, 06:13 AM | #14 |
184
Rep 2,320
FMIC 4sure
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
05-04-2012, 08:04 AM | #15 | |
915
Rep 3,456
Drives: Harrop E90 M3
05-04-2012, 08:25 AM | #16 | |
208
Rep 2,558
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife |
05-04-2012, 09:01 AM | #19 |
915
Rep 3,456
05-04-2012, 09:12 AM | #20 | |
547
Rep 2,590
"The N54B30 does not use the second generation Valvetronic technology found in the naturally aspirated N52 and the newer (single) turbocharged straight-6 N55. Surprisingly the engine block of the N54B30 is similar to the older generation BMW M54B30 engine - all aluminum with cast iron cylinder liners. This is because the newer N52 aluminum-magnesium engine block was not deemed as suitable for turbo-charging with the above-mentioned engineering goals. As a result, the N54B30 is physically heavier (195 kg (430 lb)) than the very light (161 kg (355 lb)) N52 engine. " I guess what he is referring too is that the iron cylinders see the majority of the meth and not the rest of the aluminum engine. |
05-04-2012, 10:23 AM | #22 |
153
Rep 3,730
Please sir explain to me how my statement was ridiculous? I guarentee you 100% meth will never touch anything aluminum inside the engine. We do not spray directly into our cylinders, so meth is completely atomized before it enters the engine. To be corrosive to aluminum, it would have to sit in a pool of liquid aluminum. Do frequent oil changes and you will never have an issue.
