Which gear on dyno?
05-03-2012, 10:57 AM | #1 |
36
Rep 332
Which gear on dyno?
Which gear do you select when you dyno your car?
I use 5th gear as the gear ratio is 1:1 and represents the actual power transfered from the gearbox to the diff, ignoring the losses.
05-03-2012, 11:01 AM | #2 |
177
Rep 6,631
If your car doesn't have a speed limiter, 5th is ideal for sure. We tend to use 4th to avoid pegging the limiter.
E90 LCI N54 6AT
05-03-2012, 11:07 AM | #3 | |
36
Rep 332
I think 4th gear tends to give more hosepower and better under the area power. I just wanted to know which is the most appropriate gear for a dyno and which gear represents the most accurate hospepower and torque results My mistake: my car is 6MT
05-03-2012, 11:16 AM | #6 |
36
Rep 332
4th gear ratio is 1.192:1
This means that you get 19.2 % more power than with 5th gear, ignoring tranny losses. Forgive me if I'm wrong. Tuner's opinions would be appreciated after their vas amount of dyno pulls
05-03-2012, 12:12 PM | #7 |
161
Rep 7,377
4th
05-03-2012, 01:08 PM | #9 |
30
Rep 1,041
I've tried 4th, 5th and 6 th gear on the same dyno on the same day, there's virtually no difference. I prefer 4th, simply because it stresses the car the least
E92 335i 2008 Space Grey 6MT | Pure Stage 2 turbos | Motiv PI | Trueform Tech Intake | Quaife LSD | M3 Suspension kit | Öhlins Road & Track Coilover | DEFIVfab N54 diff lockdown kit | COBB PTF E85 Map | Fuel-It Stage 3 LPFP | NGK 5992 plugs | Wagner FMIC | Wagner 3" DP | Milltek exhaust | Tial BOV | SPEC Stage 3+ clutch | SPEC Steel SM Flywheel |
05-03-2012, 03:20 PM | #10 |
220
Rep 880
i did 3rd gear as the dyno operators dont like 120+mph speeds on there dyno.... my car stock put down 254hp and 274tq so i dont see it mattering all that much as long as the dyno is synced properly
05-03-2012, 04:43 PM | #11 | |
15
Rep 432
^^ Genuine question btw . . . |
05-03-2012, 05:54 PM | #12 |
9
Rep 369
Dyno takes into account gear ratios so it technically shouldn't matter what gear you do it in. A longer gear will give you more data points however. 4th is a good compromise.
05-05-2012, 12:21 PM | #13 |
36
Rep 332
So, a well calibrated dyno will show up the same results with any gear.
I remember from my 2 dynos I performed, they left the car rolling for a while and then they inserted the selected gear, rpm, wheel specs and current speed to determine the overall gear ratio. After they revved up my car to 7000 rpm they left it rolling until the dyno determines the overall tranny and wheel losses. Next time I'll dyno my car, I'll try it both with 4th and 5th gear (as long as the wheels will not slip on 4th gear). thank you everyone for your opinions
