Can 50/50 Meth Mix get me to 400rw
05-03-2012, 01:19 AM | #1 |
68
Rep 511
I was looking to do the WW meth kit since I don't want to run a trunk mount, but I am afraid to run any more than 50/50 in the WW tank.
Tune+meth only at a 50/50 ratio am I likely to hit the 400rw mark? Using 94 octane pump gas. How much hp do you give up anyway running 50/50 versus a higher ratio? Last edited by SuperBmw; 05-03-2012 at 02:57 AM.. |
05-03-2012, 03:06 AM | #3 |
29
Rep 968
Drives: 2007 335i Coupe
With tune+ Meth you can hit 400whp
With FBO and tune without Meth you can also hit 400whp |
05-03-2012, 03:38 AM | #4 |
161
Rep 7,377
The mix only allows you to run more boost and steady ignition which in return allows you to make power. You need to log ignition with different boost settings and see if you get any drops. When you start getting drops , lower boost. Basically find your sweet spot.
05-03-2012, 06:25 AM | #6 |
Rainbow Racer
1008
Rep 2,540
+1, couldn't have said it better myself.
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
05-03-2012, 12:43 PM | #7 |
3436
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
I use 50/50 only as I use a front mount with 91 octane and I will be dyno'ing on the 18th so i will post up. I only have Procede, meth, DCI and 2.5" catlezz dps.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
