DCI: the good and bad
05-01-2012, 07:13 PM | #1 |
12
Rep 131
The good: I've been waiting a week of these parts to come in, but I finally got my DCI installed and I gotta say that turbo spool sounds amazing. I didn't think it was going to be that loud but man it feels like a whole new car.
The bad: It was 85 degrees today and for the first time my temp hit 250 about 15 min into my drive. Usually it's at like 230 maybe 240 after some wot runs, so is that normal? Have others experienced there temp gone up after installing a DCI. Last edited by Jabber88; 05-01-2012 at 07:21 PM.. |
05-01-2012, 07:36 PM | #2 |
97
Rep 2,002
The dci makes no difference in heat for my car, maybe you were " on it" more so u could hear the dci? Do u have a oil cooler?
ESS 650 ACM-R Upgrades |
05-01-2012, 08:07 PM | #3 |
169
Rep 1,247
I noticed after modding the car my temps are alot higher also. But I have an 07 and no oil cooler. So Im assuming that doesnt help at all. Temperatures havent been so high in philly maybe 72 and my car gets up to like 250-260 pretty fast. But I havent seen it higher then that yet.
2009 E92 BMW M3.
05-01-2012, 08:19 PM | #5 | |
40
Rep 462
Irub |
05-01-2012, 08:53 PM | #7 |
148
Rep 965
Drives: e92 m3
dci + meth huge diff
e92 m3 dct
gintani stage 2+ full ethanol custom pulley and meth kw clubsport,ap racing radical,volk te37sl,akrapovic rear,recaro profi xl,voltphreaks battery |
05-01-2012, 09:37 PM | #8 |
12
Rep 131
I have an 07 sport package and unfortunately no oilcooler, which is a bummer. I was on and off the throttle but just til they spool and let off. Well damn I'm sure this is just a foreshadowing for what this summer is going to bring with no oilcooler. But I don't ride my car hard, so hopefully I'll be ok.
05-02-2012, 12:02 AM | #11 |
3431
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
Where's Mike@n54tuning. Usually he jumps in DCI threads and defends them...saying that they never cause increased IAT's, oil temps, blah, blah, add link to Terry Burger's biased test, blah.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
05-02-2012, 09:39 AM | #15 |
12
Rep 131
I was just trying to see what others had experienced, not start a gangbang thread here. This isn't a Bms DCI I have, it's a custom if you wanna call it that. I did it just for the time being and will most likely change to Afe later on. It's simple tho... you don't like Bms's intake don't buy it, there are plenty other well designed intakes out there for our cars.
05-02-2012, 09:54 AM | #16 |
102
Rep 1,903
Drives: e92 335i 6MT
My oil temps only hit 250 after back to back hard pulls. Usually, it hovers around 230 just cruising around and perhaps 240 in heavy stop and go traffic. I have the Stett cold air intake and OEM oil cooler.
05-02-2012, 10:10 AM | #17 |
24
Rep 288
05-02-2012, 10:18 AM | #18 | |
79
Rep 2,396
Drives: '08 E90 335i
This is where 99% of the forum users will tell you search this topic b/c there's about 8 billion threads about intakes, but for every thread you'll get 90 different opinions on DCI vs. Stock, Aftermarket boxes, DIY's, etc. Census says that the best intake that doesn't break the bank is a Mr5, from there it's a crap shoot. With the stock box you get air directly from outside the car, which will be a cooler temp (since you live in the tri-state area & not Texas). The DCI is suck in air from the engine bay, which will only get hotter as you run the car. Regardless, my recommendations are (regardless of a tune or not) is that you either get an oil cooler or upgrade your FMIC. Either of these will address your cooling issue and should get your through a Tri-State summer (as long as it doesn't get like last year in Aug when temps were 100+ for a week straight) no problem. |
05-02-2012, 11:55 AM | #19 | |
3431
Rep 6,771
Drives: 2016 BMW i8
05-02-2012, 12:06 PM | #20 |
2007 335i E92
44
Rep 624
already f'n 80s here in ohio, put dci on in the fall, seems to be running hotter already.. kinda tired of the sound now too so building my MR.5 intake this weekend.. Will just feel better knowing its getting colder air to start with.. FMIC going on as soon as i can find a deal.. so if anyone is selling..
2007 335i E92 AT - MHD E85 Flash, xHP Stage 3 , MR5 Intake, VRSF DPs, VRSF 7in FMIC, ER CP, Fuel-It Stage 1, RB PCV, UUC Corsa Exhaust, BL R8 Coils, Sachs SRE Coilovers, M3 Control Arms, H&R Sway, BA Diff Lock, MDF Scoops, Tint, CF Hood, Mini Battery :: 2011 X3 xDrive 35i - MHD Stage 1, Alum Charge Pipe
05-02-2012, 12:55 PM | #21 |
79
Rep 2,396
You're best off searching the group buy (they're running spring/summer deals right now) or the used sections. I'm probably gonna end up buying a helix so when COBB releases their Stage 1 + FMIC map I can use that through the summer.... Very excited for the beta maps to be officially released
05-02-2012, 01:04 PM | #22 | |
12
Rep 131
