Vishnu/FFTEC Single Turbo: New plugs and Compression Test
05-01-2012, 06:52 PM | #1 |
1748
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
One thing we have been doing routinely is compression testing our single turbo test car to see how it is holding up to all this abuse/power level. For those who haven't been following from the start, this early build 2007 has been run hard from as early as 200 miles. It is, after all, our one and only in-house n54 development mule. So you can imagine that we started to pay a lot more attention to compression results since we started making 600+whp nearly 6000 miles ago. This morning, we pulled the factory plugs (which were installed 6000 miles ago) and replaced them with NGK 5992 plugs (single tip iridium):
The old plugs: Old compared to new NGK plug: Then we did the compression test: And the results were pretty much perfect: Cyl...PSI First crank 1...120 2...120 3...122 4...120 5...119 6...120 7th crank 1...165 2...160 3...160 4...160 5...165 6...160 The only "issue" we noticed is that the valve cover gasket is leaking slightly in the spark plug hole for cyl 3. So if that is the ONLY thing we have to fix in a 88,000 mile heavily abused engine, we're happy Cheers, shiv Last edited by OpenFlash; 05-01-2012 at 07:17 PM.. |
05-01-2012, 07:10 PM | #2 |
177
Rep 6,631
Welcome to my world lol.
Ps my car cranked 90-120 psi on a single crank regardless of which cylinder it was. When I cranked it a bit longer I'd see 135. Never cranked it over 7 times though. You planning on replacing all the bolts with new ones or reusing?
E90 LCI N54 6AT
05-01-2012, 07:24 PM | #4 | |
1748
Rep 17,960
Drives: A Lot
I don't plan on doing the valve cover gasket anytime soon. The leak is tiny and not causing any issue. Will probably get around to it once we install the built motor. Last edited by OpenFlash; 05-01-2012 at 07:37 PM.. |
05-01-2012, 07:25 PM | #6 | |
1748
Rep 17,960
Drives: A Lot
Compression ratio is rated at 10.2:1 Last edited by OpenFlash; 05-01-2012 at 07:38 PM.. |
05-01-2012, 07:55 PM | #7 | |
13
Rep 233
Itching to hear this. The fact that its been hush hush for this long leads me to believe its very easy and/or cheap to implement, so keeping it under wraps is pure business strategy (and rightly so). |
05-01-2012, 07:59 PM | #8 |
1748
Rep 17,960
Drives: A Lot
05-01-2012, 08:10 PM | #10 |
83
Rep 2,291
Or it's a lot different that people expect or not exactly what they expect...
2jZ + RB26 + 4G63 + LS9 + N54 =
05-01-2012, 09:41 PM | #11 |
The bigger they are...
18
Rep 264
Would like to know this also.
Tom Williams BMW Service Advisor
'07 335i Sport 219M Wheels, MMW CF Lip, Shadowline Taillights, Vishnu Procede, BMS DCI, BMS OCC, Aasco LW Flywheel, South Bend Clutch, Turner 90mm Studs, Stoptech pads rotors and lines, BMS LED Tag Lights, BMS Clutch Stop, BMS Clutch Non-Delay Valve, ACS Style Rear Glass Spoiler |
05-01-2012, 10:05 PM | #12 |
177
Rep 6,631
Those NGK plugs have been used by a few RB turbo guys well before Shiv even mentioned it in this thread. They're one step colder than stock and will work perfectly fine.
Hell, it's a small miracle that the stock plugs hold up under the power of any legitimate turbo upgrade solution as it is. N54 = an overengineered marvel. Now, if we could only get some larger injectors and a heavy duty HPFP....
E90 LCI N54 6AT
05-01-2012, 10:13 PM | #13 |
9
Rep 262
Drives: 09 911 C4s
wow 88k is really good for a valve cover gasket. Mine started leaking at 30k.
05-01-2012, 10:15 PM | #14 | |
177
Rep 6,631
Mine was probably toasted before 30k since I pulled my plugs at 34k and saw oil on one of them.
E90 LCI N54 6AT
05-01-2012, 11:00 PM | #16 |
Rep 2
That is also leaking vacuum. It's possible that it is visible on a dyno chart as jitters.
05-01-2012, 11:28 PM | #18 | |
Team Zissou
3082
Rep 10,198
that being said i'm currently trying to figure out what seems to be a boost leak... probably a long shot and totally off but could a leaky valve cover gasket cause boost leak-type symptoms (not hitting boost target, with maxed wg duty cycle). |
05-02-2012, 12:17 AM | #19 | |
308
Rep 5,175
05-02-2012, 12:45 AM | #20 |
161
Rep 7,377
no missfires. i had these on for 4000 miles now with 2 track days, races etc.
05-02-2012, 12:51 AM | #21 | |
Team Zissou
3082
Rep 10,198
05-02-2012, 07:16 AM | #22 | |
29
Rep 1,551
Stretch bolts. Replace em. |
