2010 2011 BMW 5 Series Forum F10 alignment after spring install? |
04-27-2012, 04:55 PM | #1 |
35
Rep 133
I'm having my ACS springs installed next week at my dealer.
They seem to believe that an alignment should be done right away as good quality springs don't settle. They say that every spring install they've done (Dinan, H&R etc) went with an alignment right away and never displayed any problems. What do you guys think? Last edited by nwills; 04-27-2012 at 05:01 PM.. |
04-27-2012, 05:10 PM | #2 |
276
Rep 722
nwills,
when I installed my H&R springs I had it done by a local shop in Mississauga that mods bimmers and built a BMW track car for fun. When I asked them what they would recommend for alignment they did not hesitate to say to wait for a month to let the springs settle. Also, the guy said that it's really hard to mess the alignment of the springs on our cars since everything comes together to align close to 95% without a formal alignment. I am no mechanic so I am just qouting what he said. I did what they recommended and had no problems. Hope this helps. MBA |
04-27-2012, 05:32 PM | #3 |
256
Rep 4,721
well, the consensus suggests between 48 hrs to 1 month time. Larger % of those who had done the springs (from different car forums) all agreed and suggested to let the springs settled and then do the 4-wheel alignment within that time range. The large time range may have to do with how the springs react to the car's weight as being one of the important factor. Therefore, I had previosuly suggested 1 week or so time.
04-27-2012, 05:35 PM | #4 |
35
Rep 133
that's what i gathered. Everything I've read always suggests to let them settle first.
It was the first time I had anyone suggest otherwise. The dealer seems pretty adamant that good springs don't settle. I think I'll probably take the safer route and give it a week before the alignment is done. |
04-27-2012, 05:39 PM | #5 |
29
Rep 585
I had my 550i alignment checked after spring install, and it was still within specs. After 15k miles, I've had perfectly normal tire wear all around.
04-27-2012, 05:46 PM | #6 |
256
Rep 4,721
op, you getting them installed @ BMW Toronto ? I would have thought you are getting them done @ RMP or bimmersport or others
I am having my alignment done end of May. |
04-27-2012, 06:08 PM | #7 | |
35
Rep 133
As a result I'm worried that if the spring install results in any strange behavior I can always hold BMW to take care of it and be sure that they'll stand behind their work. They probably wouldn't of let a bad wheel balancing job slip. They road test the car after a wheel install. This shop didn't. They would never scratch a rim and if they did (happened once) they have the wheels refinished. All this makes me paranoid and I figure I'll be more confident if they do the work. I'm paying a serious premium for this but the car is two weeks old and I already have vibrations and scratched rims. I'll let them do the spring install, re-balance the wheels (road force), 4 wheel alignment and tweak camber etc if need be to make the car smooth and perfect. This may sound somewhat irrational on my part but I want it perfect! So far I was quoted for the spring install and alignment: $420/$650/$1000/$950 The two top prices came from the dealer and another tuning/dealer. The lowest price seems very low in context....I really don't want to deal with any potential issues. |
04-27-2012, 06:46 PM | #8 |
256
Rep 4,721
sounds like I was in the same position as you when I got my car. But I have not done anything mechanical yet to my car and it's already 1.5 years old. The only 2 things I want to do on mine are just KW coilovers & tune. Neither are available after the F10's been out for 2 years+ now.
If nothing is coming out by end of this summer, I will not do anything afterall as I will be shopping for my next car in spring/summer 2013. |
