Aftermarket clutch users come in!
04-25-2012, 05:36 PM | #1 |
14
Rep 252
How much does it usually run for a clutch installation ? and what about OEM flywheel re surfacing?
Also any recommended south florida shops? |
04-25-2012, 05:46 PM | #2 |
70
Rep 2,626
I paid 2205$ to replace and install my ACT street clutch:
-New Flywheel (Had to buy a new one 930$) -New clutch with OEM parts 600$ -installation 675$
'18 F80 M3 Comp 6MT - Stock
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
04-25-2012, 05:48 PM | #3 | |
14
Rep 252
if im not getting a new flywheel and just getting it resurfaced, anyone knnow how much that would run? also what bolts do i need to buy? throwout or any bearings or anything? |
04-25-2012, 05:55 PM | #4 | |
70
Rep 2,626
Now with taht said, if the shop has done the clutch job on a 335i before, you might get the install for cheaper. 500$ should be what they charge if they've done it before. Pilot and throwout bearing and aluminum bolts for the bell housing. ARdesign sells the clutch along with all the OEM parts. I bought everything from them (except the flywheel)
04-25-2012, 05:56 PM | #5 |
70
Rep 2,626
and since your'e down there why not change transmission fluid. I went with Redline D4 ATF after having tried OEM and royal purple max. Shifting never felt better.
04-25-2012, 06:02 PM | #6 |
14
Rep 252
Okay thanks so much, now i need to figure out somewhere i can resurface my flywheel and a price on it..
04-25-2012, 06:03 PM | #7 |
70
Rep 2,626
sure, goodluck
04-25-2012, 07:04 PM | #9 |
131
Rep 2,978
I just got this done last month. Here's the breakdown:
1. ACT 6 puck - $440 (I ended up buying an OEM one. So this one is for sale for dirt cheap. 2. OEM clutch kit (throwout bearing and bolts were included) - $375 3. OEM flywheel - $740 4. Labor - free (installed it myself) |
04-25-2012, 07:19 PM | #10 | |
14
Rep 252
04-25-2012, 07:46 PM | #11 |
131
Rep 2,978
The 6 puck is not what you want to use for a daily driver. It is a more aggressive clutch (designed for drag racing). Basically, if you want to buy mine, you can either 1) deal with the rough disegagement or 2) use the pressure plate and get a new disk from ACT.
Throwout bearings and the bolts aren't expensive. It wasn't hard for me at all, especially the second time I had to do it I did it out of my garage on jackstands |
04-25-2012, 08:15 PM | #12 | |
14
Rep 252
04-25-2012, 08:22 PM | #13 |
131
Rep 2,978
Honestly, the hardest part at first was taking the two bolts behind the motor, under the hood. I didn't use the proper ratchet.
The second time I did it, I bought the right ratchet. The whole process only took me about 6 hours (uninstall/install). I am not sure what to compare it to....Watch the video that HPF posted on youtube. It's really easy. |
04-25-2012, 08:31 PM | #14 |
178
Rep 11,768
on my last car i spent maybe 500 for install, but had to buy new flywheel and such which brough total up to 1.5k.
-Rev
SGM e92 335xi|Helix|AFE|AWE|PROCEDE|SYNAPSE|ER|OSS|BMW PERFORMANCE|P3|always growing.. |
04-25-2012, 08:40 PM | #15 | |
14
Rep 252
04-25-2012, 08:41 PM | #16 |
178
Rep 11,768
clutches are a PIA take it from me, get it done from a shop, if you dont align it right or dont have the flywheel surfaced 100 percent, youre going to get bad vibrations.
-Rev
04-25-2012, 08:58 PM | #17 | |
131
Rep 2,978
That's why you need to buy the clutch alignment tool |
04-25-2012, 09:59 PM | #19 | ||
14
Rep 252
04-26-2012, 11:57 AM | #21 |
70
Rep 2,626
That is a lot money. My dealership quoted me 900$
04-26-2012, 12:23 PM | #22 |
131
Rep 2,978
Not everything...
Not to be an a$$, but it sounds like you may need to pay someone or do it with someone who knows what he's doing. Keep in mind, this is not an easy job for someone that's not mechanically inclined. Also, this is a two people job (when installing and uninstalling the transmission) |
