Driving 6MT for fuel economy
06-19-2007, 10:18 AM | #1 |
e92 Arrived 5/12
Rep 86
So after filling up my car every week because I've been ecstatic about my 335i, I'm ready to settle down and get some good gas mileage out of my car.
I have a 6mt e92 335i and was wondering what were your recommendations for driving stick for better fuel economy? What rpm's or speed are you guys changing gears? Is there a general rule for changing gears? I've heard 3k rpm is a good point but I'm really looking to get the best fuel economy out of my car when I'm not trying to make it purr. Thanks for the advice. ps. Please no comments about I should have bought a geo if I wanted good gas mileage. |
06-19-2007, 10:21 AM | #2 |
99
Rep 1,828
Drives: 2016 Tesla Model X P90DL
keep it under 2K rpms most of the time (2k is shifting point)
roll on neutral where you can slowly accelerate from the stop using all that gave me 37.8mpg on my 330ci on freeway and 26+ mixed |
06-19-2007, 10:33 AM | #4 | |
Too many Alex's, from now on, call me Beaufort
342
Rep 6,188
Its like on a bike. You can put it in a higher gear but you have to exert more force(gas) to get the bike moving faster(or at all). Its better to keep it in a lower gear until youre at a speed where you can be steady at then put in a higher gear to keep the revs low. Just my opinion.
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip 16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone) 07 335i(gone) |
06-19-2007, 10:35 AM | #5 |
99
Rep 1,828
06-19-2007, 10:37 AM | #6 |
4972
Rep 10,200
Drives: 2024 Golf R / 2022 718 Spyder
I agree that 3K is probably best--slow acceleration is probably the biggest factor, taking off slowly should really help out your MPG.
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
06-19-2007, 10:37 AM | #7 | |
99
Rep 1,828
To each his own |
06-19-2007, 10:38 AM | #8 |
342
Rep 6,188
Thats at WOT. Who the hell drives WOT all the time to conserve gas? I think the statement that your mpg will drop "big time" is unlikely. This car will move just as easily without getting on boost and you can save gas. We arent suggesting shifting at 5k, 3k is a safe point where you arent stressing the engine much to push it. 2k is silly, its just barely above idle(not really but close).
13 HD FatBob
06-19-2007, 10:39 AM | #9 |
Rep 337
I can't get a smooth shift from 1-->2 or 2-->3 if I'm at 2K. I usually shift at 3-3.5, especially when the car is cold. Is this a CDV thing?
That said better gas mileage would be good but then I'm still under 2K miles on the car so I'm sure it will improve.
E90 335i: TiAg, black leather, burl walnut, 6MT, Sport, Premium, Cold Weather, PDC, Sirius, Comfort Access, Nav
ED: 3/30/2007 Redelivered! 5/15/2007. |
06-19-2007, 10:41 AM | #10 |
342
Rep 6,188
How about this to the OP. Drive different styles for a couple tankfulls. Try to drive the same routes all the time, if you commute that makes it easier. Dont take any long distance trips to find out. After a couple tankfulls, youll find what works best for you.
Im getting between 17-19mpg right now because my commute is completely stuck in traffic. I HIGHLY doubt shifting at 2k instead of 3k is going to make my mpg magically improve. On top of that, Its not when you shift that really saves gas, its how hard into boost you get that sucks it down.
13 HD FatBob
06-19-2007, 11:21 AM | #11 |
193
Rep 2,443
+1 I think the CDV mod will help with that. I am installing mine later this week...hopefully it will help with the 1->2 shift
06-19-2007, 11:59 AM | #12 |
50
Rep 755
Drives: '14 228i
Actually, the lower RPMs you can shift without bogging the engine, the better. Medium to even high throttle (though probably not WOT), doesn't hurt mileage as it lessens the time you spend accelerating (which is when you use the most gas). Bottom line: revs are the enemy, not throttle opening.
2014 228i
alpine white | sport line | 6-speed manual | lighting package | driver assistance package interior - black Sensatec | aluminum & red trim |
06-19-2007, 12:04 PM | #13 |
342
Rep 6,188
So If Im firmly pressed on the gas(maybe 4-5lbs boost) from a standing start(500rpm) and shift at 2k Im not using any more gas because Im still shifting at 2k? That doesnt make sense considering I can drive in vacuum (-02.to -00) and still accelerate but shift at 2k(obviously not as fast). However, if Im doing that and I shift to 2nd at 2k then I get into boost trying to get up to speed again. However, I could still shift at 3k without getting into boost and shift into 2nd but be in a higher powerband where I can still stay in vacuum and accelerate. The second I see my boost gauage go over that 0.0 mark, I know my fuel is going somewhere faster than not and it has no care where Im shifting.
13 HD FatBob
06-19-2007, 12:21 PM | #14 |
AC
95
Rep 2,387
Driving "normally" on a flat surface, I usually shift between 2,500 - 3,000 RPM on other non-turbo cars.
For the 335i, I keep it between 2,000 - 2,500 RPM on "normal" driving. Once both turbo kicks in full-force (~2,300 RPM on my car), you are simply burning "cash". The above scenario is for "flat" surface only, actual RPMs between "shifts" could be higher or lower depend on whether you are accelerating uphill or rolling downhill.
Your Supreme Leader
06-19-2007, 12:32 PM | #15 |
STEVIL Empire
218
Rep 6,297
IMHO, I drive without regard to gas mileage but more to circumstance. If I'm in stop and go traffic or just running local errands, I will shift at a lower RPM point than if I am doing spirited driving like getting onto the highway or having some fun on the twisties. No need to clutter the mind with 'what kind of gas mileage am I getting' when I'm enjoying the Ultimate Driving Machine.
2007 E92 328i 6MT-Space Gray/Black Dakota/Gray Poplar w/heated seats-PCD 4/27/07 (SOLD)
2009 E90 328i xDrive 6AT-Space Gray/Oyster Dakota/Dark Burl Walnut w/ZPP,ZCW,Xenons-ED 4/17/09 - Redelivery 5/30/09 (SOLD) 2014 E84 xDrive28i 8AT-Alpine White/Black Nevada/Silver Matte w/ZMV,ZLP,494 - DD 3/14/14 (SOLD) |
06-19-2007, 12:42 PM | #17 |
342
Rep 6,188
Who am I kidding, I live in the state with the cheapest gas(just got 93 for $2.99 yesterday). Im in it to win it. What do I care if I save 2mpg.
13 HD FatBob
06-19-2007, 12:45 PM | #18 | |
Rep 37
06-19-2007, 12:52 PM | #19 |
Clutch pedal >> Dead pedal
18
Rep 709
Drives: '11 e92 335is 6MT
^^^ +1
I think that's the second time I've seen that from Achien. Anyhow, FWIW I shift at 3-3.5k on the 1-2 shift, then 2.5-3k on the 2-3 shift, and tend to shift at around 2k in subsequent gears. This depends on the road incline and speed limit, traffic, etc.
In my garage: '11 e92 335is 6MT (05/10) SpGrey/CoralRed/GlacSlvr ExecPkg/NavPkg/19" 225M
Retired: '07 e92 335i 6MT (12/06) SpklgGrpht/CoralRed/GreyPoplar Retired: '04 330Ci M-Sport 6MT SilverGrey/NaturalTan/MyrtleWood Retired: '00 328Ci 5MT SteelGrey/Grey/MyrtleWood Retired: '87 Pontiac Grand-Am 3AT White/Grey |
06-19-2007, 01:11 PM | #20 | |
50
Rep 755
Drives: '14 228i
In any case, you might find this interesting: Road & Track - Technical Correspondence, November 2005 -Dan
2014 228i
06-19-2007, 01:14 PM | #21 |
15
Rep 211
Take the bus! I have found that I burn a lot of extra fuel by speeding up and slowing down on the freeway. Speeding up to pass a car and then eventually hitting traffic to find the guy right next to me. (Don't you hate when that happens). Anyway, I think saving gas is all about keeping constant speed rather than shifting points.
06-19-2007, 01:15 PM | #22 | ||
AC
95
Rep 2,387
Your Supreme Leader
