Anybody ever lose a C-clip from a wastegate actuator rod?
04-17-2012, 04:32 PM | #1 |
19
Rep 650
Problem history here:
http://www.e90post.com/forums/showthread.php?t=677198 Dealer is saying the C-clip was lost. I've never lost any of the WGA hardware from either of my other turbo vehicles...seems a bit odd. Also, they are acting like it's really difficult to get to, almost as bad as changing the turbos. I haven't crawled under the car yet since I bought it, and it's at the dealer now. Is it really that difficult to get to? |
04-17-2012, 04:43 PM | #2 |
161
Rep 7,377
if its the front turbo well its a lot of work....
04-17-2012, 05:26 PM | #4 |
65
Rep 1,708
rear easy, front hard. I don't remember exactly but the front WGA is between the turbo and block. Removing the front DP from the turbo may help give you access. You'd have to move steering rack, maybe the heat shield... but I don't remember well. Could be a good time for DPs if you don't have them.
04-17-2012, 05:37 PM | #5 |
387
Rep 1,571
So what are they proposing? The c-clip is about $.50.
What also happens is that the whole pin can break off the lever, seen it numerous times. That would require a new turbo. |
04-17-2012, 05:44 PM | #6 |
1743
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
A customer had the c-clip of the rear turbo pop off. Even that took some effort to replace with a lift (from underneath). Front turbo will require quite a bit more work.
04-17-2012, 07:33 PM | #7 |
19
Rep 650
OK, thanks for the input. Luckily this time it's covered under CPO. Looking forward to putting a single on and trading these types of problems for other types :-).
04-17-2012, 07:37 PM | #8 |
394
Rep 3,161
This happened to me a few years ago while on the dyno.
2015 M3 BPM Tuned, Eibach, Magnaflow and more www.tmrmzine.com/m3/f80
SOLD E92 Slēk Carbon Fiber Widebody M3 www.tmrmzine.com/m3/slek/ SOLD E92 335i Stage 3+ with all the toys www.tmrmzine.com/335/ SOLD E39 M5 Modded, What a great car! www.tmrmzine.com/m5/ |
04-17-2012, 07:44 PM | #9 |
177
Rep 6,631
Rear turbo cotter pin isn't too hard to replace, simple as taking off a set of downpipes, but that front one, forget it lol.
E90 LCI N54 6AT
04-17-2012, 10:49 PM | #10 |
915
Rep 3,456
Drives: Harrop E90 M3
The C clip is not available separately from BMW. Also depends if it's an early turbo or later. The early wastegates are about 6mm and the newer ones are 8mm.
