F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Will these wheels fit?
Extreme Powerhouse
      04-16-2012, 12:30 PM   #1
EuroTunerz5
37
Drives: 2012 AW BMW 135i M-Sport PPK
Rims Size: 20 X 8.5" fronts & 20 X 10" rears
Bolt Pattern: 5 X 120
Offset: 15 mm fronts & 20 mm rears
Hub Bore: 74.1
They are Monza wheels.... absolutely stunning.
Also, what size tires would you all recommend on a 2012 f30 sport lowered on HR Sport?
2012 BMW 135i M-Sport PPK AW with Black Boston Leather- SOLD
2010 Acura TSX V6 Tech BSM
2003 Corvette Z06 TR "Widebooty"
      04-16-2012, 03:46 PM   #2
SD_E88
SD_E88's Avatar
Drives: 12' 135i E88 Black
Highly doubtful. Way to wide in the back and probably .5 in too wide up front. You might get the fronts to work but you will scrape up the wheel well when turning. Stick with 8" up front, 8.5" rear.
      04-16-2012, 05:24 PM   #3
EuroTunerz5
37
I should rephrase.... I know the width is fine. There are members with 10.5 rear and 9 up front. I am concerned about the offset more or less. Thanks for the reply though!
      04-16-2012, 05:46 PM   #4
EuroTunerz5
37
I should ask what is the recommended offset range for the F30 front and rear with an 8.5 front and 10 rear.
      05-01-2012, 06:35 PM   #5
Rich2k1
Rich2k1's Avatar
Drives: 2014 435i
The 15mm and 20mm offsets will be poking out. I ran a 20x10.5 +45 rear and fits flush the 20x10 +38 as well. The front 8.5 or 9 with a 35 or 8 with a 32 should be ok but you will need mud flaps with the low offset,that is for a 5or7 series.
F32-M4 CONVERSION,STANCE WHEELS, KW SUSPENSION,DOWN PIPE AND FULL IPE VALVETRONIC EXHAUST. M PERFORMACE CARBON FRONT END.
      08-02-2012, 02:50 AM   #6
awhk
88
Drives: 2023 iX M60 SBM
So what tire width are you recommending for 20x9 +35 front and 20x10 +38 rear? 225/35, 255/30 or 245/30, 285/25?
      08-03-2012, 01:14 AM   #7
Merlin93
The New Guy
Merlin93's Avatar
Drives: '06 Z4 3.0si Roadster
I'm no expert, but just running through some experimental tire sizes vs those rims, I believe that 255/30's are probably the smallest you can fit on a 10" rim (most 255's don't need more than 9.5"), though it would work much better with 265's or 275's. You might have problems fitting the 275s in the wheel wells depending on your suspension and brakes. In the front you'd probably want to stay with 235/35's or larger with the 9" rim, 245's are about as big as you can go up front though, with the same potential issues as the 275's.
2013 328i Sport Line-Alpine White w/Coral Red ZTP ZPP ZDA ZDB ZDH ZLP 494 5DF 5AC 5DP 688 302
2006 Z4 3.0si Roadster-Black Sapphire w/Black, Sport & Premium Packages, Xenons, Heated Seats, Nav
f30post
