Help with Procede
04-14-2012, 06:55 PM | #1 |
25
Rep 467
Help with Procede
I ordered the Procede Rev3 from the USA ($780 delivered great price) and received it last week. Yesterday I began the installation following the YouTube video step by step and all was good until I got to the 4.37min mark which the instructions said I should avoid and jump to 4.56min and continue, however, one issue, in the box from the USA is the following:
There were no instructions on how to install this? I don't know what it is. I completed the installation anyway without the above and all seems ok, just need to test this morning as I ran out of time and I was off to watch my team get flogged at Eithad last night. There are two red wires coming out of this little black cube (about 3.4cm) with no ends,(see above) and there are also two red wires coming out of the rev3 box but with connectors - see below circled in yellow There is also another connection circled in Red above that seems to go nowhere as well? ** Also, those of you who have installed the USB cable, did you leave it plugged into the Rev3 box, and then what did you do, ie did you pass it through to the glove box? Would appreciate any help before I put the covers back on. |
04-14-2012, 07:09 PM | #3 |
25
Rep 467
04-14-2012, 07:15 PM | #4 |
69
Rep 2,934
Yes and no. At the back of the ecu box (best IMO to the everything out of the ecu box first) there is a fan with two openings you need to use the one at the bottom or you will break the cooling fan for the ecu. In all take your time and you should be fine.
04-14-2012, 07:29 PM | #5 |
25
Rep 467
Ok with a bit of Googling I have found out what this is. Its a 2-step/NLS
All the details are here Using 2-Step Rev Limiter With this feature enabled, it is triggered it when the car is stationary AND with the clutch pedal depressed. When these two conditions are met, you can floor the throttle pedal and engine speed will be limited to your 2-step RPM values. Ignition will be cut when revs reach the RPM@switch off value and then resume when revs falls below the RPM@switch on value. You can enable the 2-step rev limit feature for several seconds. The longer you keep it active, the more boost generated. At a rev limit of 2500rpm, you may only be able to build 1-2psi of boost. However, with a rev limit of 5000rpm, you may be able to build as much as 6-7psi of boost. Obviously, building too much boost at launch won't do you any good if you don't have enough traction. Otherwise, all you will get is wheelspin! I don't have a manual car, so no need to install. Last edited by Michael BD; 04-14-2012 at 07:35 PM.. |
04-14-2012, 09:29 PM | #6 | |
156
Rep 4,995
In terms of the usb cable going through the firewall is pretty easy, just unplug your ECU and take it out then snake it through the hole (the 135i only has one hole so I assume follow Pavo's advice). Then from the cabin you just need to unscrew the panel underneath the glovebox and you will see the USB from there. |
04-15-2012, 01:12 AM | #8 | |
69
Rep 2,934
Dude do the job properly the first time. It's an easy job through the firewall just take your time |
04-15-2012, 01:41 AM | #9 |
11
Rep 129
Yes and no. Through the door takes literally 1 min and is non permanent. If the police find a USB cable in your glove box they will investigate further.
Also some dealers will refuse to work on your car if you have a tune. Unless you're data logging daily you are better off doing it through the door (not the window). Each to their own. |
04-15-2012, 01:48 AM | #10 |
346
Rep 2,396
That's the power relay. I don't remember exactly how to install it but if you don't run the PWM methanol or NLS you should be fine without it.
The "extra" connectors are most likely again for either PWM or NLS. |
04-15-2012, 03:12 AM | #11 | |
69
Rep 2,934
04-15-2012, 03:20 AM | #12 |
11
Rep 129
In melb they will strip your car down to the ECU if they smell something dodgy. Just ask BMWGTR what he got done for....
I wanted to do it through glovebox initially but glad I didn't in the end |
04-15-2012, 04:31 AM | #13 | |
69
Rep 2,934
04-15-2012, 05:29 AM | #14 | |
156
Rep 4,995
I suppose if that cop was going to strip your car down you must have been doing something very very bad as I don't think a cop will stop you and go straight for your glovebox straight away... ? And why would you take the car to the dealer with your tune installed it only takes an extra 5-10 minute putting the cable through the firewall (once you have done it enough time ). IMO just do it though the firewall very very easy. |
04-16-2012, 08:49 AM | #15 | ||
19
Rep 250
Come to Melbourne Pavo and if you bump into the police in your modded car, bring lube, lots of it. |
04-16-2012, 03:42 PM | #16 | |||
69
Rep 2,934
Seriously bugger the glove box and ecu, all they need to do is open the boot and see the meth tank and it's game over. |
04-22-2012, 02:31 AM | #18 | |
69
Rep 2,934
really?????? What exactly did you expect : |
04-22-2012, 05:26 AM | #19 |
156
Rep 4,995
Are you referring due to tune or due to the way we drive after tuning the car ? lol
Most people probably drive it harder after a tune and thus higher fuel consumption as a result. |
04-22-2012, 06:33 AM | #20 |
19
Rep 250
I think FreeFreeFive and BMJOE noticed some change but can't recall whether consumption went up or down lol. I just remember them talking about it.
That said, Mr 335i and Miss fuel consumption don't really hit it off. |
04-22-2012, 06:53 AM | #21 |
11
Rep 129
I'd say it's gone up for me. However I only had the car 2 weeks before the procede was installed so can't be sure.
I get around 13L/100km at the moment. I drive the car in a spirited fashion but it also spends a lot of time on the freeway. I say I could get maybe 11L/100km if I had the procede off and was careful with it. My E36 M3 used to drink 10L/100km and it bounced off the redline all day long... Man that car was awesome in every way... |
05-22-2012, 07:59 AM | #22 |
25
Rep 467
I noticed the other day the service warning light has come on telling me a service is due soon at 22,000klms. Funny thing is I have done 28,000 klms and that service was done late last year
Could the procede have thrown this up, or did the dealer service dept not reset it properly? |
