TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Australia > What Coolant?
      04-13-2012, 10:25 PM   #1
Michael BD
Michael BD's Avatar
Australia
25
Drives: BMW M340iXDrive
What Coolant?
I have a warning indicator saying coolant is low? What Coolant should I top up with?
I rang the dealer yesterday (Bib Stillwell) and they took a message and said they would ring me back, but as usual from that dealer, no one ever rings you back.
      04-13-2012, 10:34 PM   #2
taranonline
28
Drives: Man
fill it with distilled water. radiator coolant is a mix of half water and half coolant.
      04-13-2012, 11:09 PM   #3
BMJOE
BMJOE's Avatar
Australia
11
Drives: E92 335i
Hi BAD
I also had this message, I topped it up with some water....
E92 335i White Angel Eyes | BMW Black Gloss Grills | CF Mirror Covers
      04-13-2012, 11:30 PM   #4
xxx7
xxx7's Avatar
Drives: E90/E60
I topped up using BMW coolant. It costs $20 for 1.5 liters but didn't need it all. If topping up with water forum members recommend using distilled water.
Charlie 99
      04-13-2012, 11:36 PM   #5
Michael BD
Michael BD's Avatar
Australia
25
Thank you will get some distilled water.
      04-13-2012, 11:44 PM   #6
e92sydney
e92sydney's Avatar
Drives: Mobility Scooter :)
If you are in Sydney I will give you some. I bought some from BMW for the same reason, I got a warning light saying it's low, only needed about 10% of it to top it up.
If anyone in Sydney needs some, PM me, I think all the models use the same coolant as BMW seems to only have 1 type of it.
      04-14-2012, 04:44 AM   #7
greyd
Australia
Drives: 320d
Is there any particular problem caused by using normal tap water instead of distilled water, eg does it cause corrosion in the engine?
      04-23-2012, 09:09 AM   #8
cable96
14
Drives: threethreefive
A few times throughout the ownership of the vehicle should be fine, but with continued use it will cause corrosion and rust to settle in.
