Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Australia > Central locking problem on drivers door
      04-07-2012, 05:46 PM   #1
shk21
shk21's Avatar
Drives: E90 320i M Sport
Hi all,
Yesterday, when i tried to lock the doors via remote control, the drivers side would not engage locking.
It made clinking noise for a couple of seconds then give up. All other doors are fine.
I checked the fuses (56 and 57) and they are all fine.
Any ideas on what the problem is? Mine is 320i 2006 model. Thanks
      04-07-2012, 10:08 PM   #2
RaihaX
RaihaX's Avatar
Australia
156
Drives: 08' 135i
Our old e90 320i had a persistent problem with the central locking, in the end everything related to it was replaced by BMW under warranty.
      04-08-2012, 04:42 PM   #3
bmwaddiction
Australia
25
Drives: Lexus IS350 F Sport
Originally Posted by shk21 View Post
Hi all,
I had the same issue, its a common problem with e90s and normally related to 'driver door actuator' failure.
BMinimiparts.com sell them for about $32+postage, its a black platic unit the size a fist that actually locks and unlocks your door.
Have a look at the forums and you will find a number of DIYs on the issue to fix it yourself. If you are not feeling confident on fixing it then just take it to any local BMW independent - should be no more than 1 hour of labour involved. Took me and my brother in law 15 minutes, but he is quite good at stuff like that.
You door trim will need to come off as well as your door handle mechanism in order to replace the faulty unit.
I hope this helps.
      04-09-2012, 08:30 AM   #4
shk21
shk21's Avatar
Thanks. Do you know the part number or which model actuator on bmminiparts.com? I tried to look for it and there are several different models of actuator without much description and none of them is $32. Thanks
      04-10-2012, 04:14 AM   #5
bmwaddiction
Australia
25
here is a DIY that has the part number:
http://www.e90post.com/forums/showthread.php?t=477507
here is a link from realoem.com
http://www.realoem.com/bmw/partxref....r=1&series=E90
hope this helps
