Getting locked in!
06-15-2007, 05:27 PM | #1 |
Rep 5
Getting locked in!
I'm confused by recent threads which show that you can get locked in the E90/92 etc even with the CA option, and not be able to get out of the car.
First of all, when experimenting with my E92, I found out that if I "lock" the car with the CA fob after shutting the driver door, but before closing the (only) passenger door, and throw in the fob and then close the passenger door - which can happen by accident too, according to a recent post - then, even with the CA option, my fob is locked in the car - I am locked out! The CA has allowed me to be locked out! (I thought it was not meant to?). The only way for me to unlock the car is by using the other fob, or using BMW help. But more importantly, if you leave the car, but leave someone in it, you can lock them in (by "locking" the car with the fob). That person can NOT get out of the car without smashing a window (and what could they use for that?). Suggestions in other threads that you could use the central locking button or pull up the manual lock in the door etc just don't work if the driver leaves the car after switching the engine off. Or is there another way for the "locked in" passenger to get out? |
06-15-2007, 06:27 PM | #2 |
155
Rep 6,158
they can reach through the pass through in the rear seat, and activate the folding rear seat. once they get in the trunk they can pull the glow in the dark handle and escape!
if their arm is long enough and the car has folding rear seats that is |
06-15-2007, 06:32 PM | #3 |
87
Rep 1,555
much discussed topic....
simply if you lock someone in....they push the unlock dash button while simultaneously pulling on the door handles. The door will unlock |
06-15-2007, 06:38 PM | #5 |
Now With 33% MORE Sarcasm Free!
157
Rep 3,462
A BMW is Just a Car, it doesn't make you smart, handsome, clever, better, cool, or wealthy. |
06-15-2007, 07:37 PM | #6 |
94
Rep 3,748
Drives: BMW 325Ci Individual
that's a sucky thing that bmw so needs to get worked out... my father's car has CA and it won't allow him to lock his key in the car
06-15-2007, 07:38 PM | #7 |
10
Rep 1,035
Push the unlock button on the dash and pull a front door handle twice. The door will open.
May 3, '07European Delivery, Redelivered on 6/11/07 - Monaco Blue/Beige, Steptronic, ZPP, ZCW, PDC, iDrive/Navi with RTTI, Logic 7, Xenons, HD Radio
06-16-2007, 03:28 PM | #8 |
Rep 5
Thanks for your answers. I'm still chuckling over the vision of someone diving under the back seats and popping out of the trunk moments later in Houdini fashion (probably with a shout of "Surprise!").
Anyway, though I thought I had tried the various methods you mention above already, I tried them again, but they just don't work. Once locked in the car, and the driver with the fob (who has completely shut down the engine) has walked away with the fob, leaving you with nothing, as far as I can see, you are stuck there in the car... to perish. Now, I am talking about E92 here, European NOT US specs. And with CA. Lassaxi's method works when you have centrally locked the car from the inside, but try it in the case I have laid out, and it won't work (maybe in the US version it will?). smellthebeans method looked promising because it looked out of the ordinary, but sadly that doesn't work either. And now I've read in a more recent thread that you can't activate the folding seats in a E92 from the inside in any case - you have to pull the handles from inside the trunk. I hope that's not true as I was hoping to replicate the suggested Houdini trick. Adding to the problem is that the glow in the dark handle in the trunk is considered an optional thing in Europe and is not in some E92s anyway. Suggestions? By the way, on that other point, you can't lock yourself out by locking with the fob and subsequently shutting the driver door after leaving the fob in the car (the driver door won't lock), nor by slamming the fob in the trunk (because it opens up again, well, in most cases - though not all, it seems), but the combination that concerned me was when you locked with the fob after closing the driver door and then closed the passenger door after leaving the fob in the car (which might have happened to the Toronto couple with the 3 year old daughter). I haven't found anyone whose CA system reopens the car in that particular case yet - meaning, you get locked out....astra, does your father's car not lock in that situation? |
06-17-2007, 09:43 AM | #9 | |
10
Rep 1,035
