2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Offsets tolerance
      04-04-2012, 10:18 AM   #1
Amleto63
Commander
Amleto63's Avatar
Italy
14
Drives: F10 520d Sedan
Offsets tolerance
I need your opinions on replacing my OEM 18" wheels (8" ET 30 front and rear) with replica 19" ones with different offsets. According the ET calculator at tirerack it seems that they should fit if compared to the OEM 19" wheels (front 8.5" ET 33 - rear 9" ET 44).
What do you think?
OEM
Front
From 8” 245/45 R18 ET30 to 8.5” 245/40 R19 ET33
9mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 3mm
Rear
from 8” 245/45 R18 ET 30 to 9” 275/35 R19 ET44
27mm LESS clearance on the strut side, and the outside edge of the wheel will RETRACT 1mm
Agropoli wsp Italy m6 design
Front
from 8” 245/45 R18 ET30 to 8.5” 245/40 R19 ET34
10mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 2mm
Rear
from 8” 245/45 R18 ET 30 to 9.5” 275/35 R19 ET34
23mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 15mm
Stay Ahead!
E46(00-03) - E46 Touring (03-06) - E90(06-10)
      04-05-2012, 05:39 AM   #2
remmib
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
Front is only 1mm more tucked than OEM 19". Rear is more aggressive, but I doubt it'll rub.
5post
