New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      04-01-2012, 02:39 PM   #1
Warriortogo
Warriortogo's Avatar
14
Drives: 2011 Z4 35is 2008 135i
Which engine oil do u guy use in your Bimmer?
Tried Redline 5w40, Motul 300V 5W40, Mobil Ultimate 0W40
Using Pakelo 10W60
Seem redline shoud be the best
Any comment?
2011 Z4 35is Alpine White DCT Alcon BBK KW V3 Supersprint Exhaust Procede
2008 135i Le Blue Alcon BBK JB4 Hartge Exhaust H&R Sway Bar M3 Suspension Forge DV Forge FMIC H&R premuim damper Kit
      04-01-2012, 04:47 PM   #2
az34
az34's Avatar
54
Drives: 2009 z4sdrive35i 2008 x5 3.0i
why dont you used the one recommend by your car builders:Castrol Syntech.
      04-02-2012, 06:59 AM   #3
Alpha_Zulu
Alpha_Zulu's Avatar
Drives: 2014 Z4 35is, Alpine White
Normally I'd agree with you, but I'm going to have to say that the Castrol Syntech oil they use in the bimmers is garbage. Especially with those high mileage oil services, the oil just doesn't hold up.
I use Mobil 1 oil with the BMW Filter.
      04-02-2012, 09:19 AM   #4
DavidJS
Drives: Z4 sDrive 35is
Those of you who use Mobil 1, do you use regular Mobil 1 or "Extended Performance"?
      04-02-2012, 10:12 AM   #5
Warriortogo
14
You should try redline once. You will know "WHY"
      04-02-2012, 03:43 PM   #6
az34
az34's Avatar
54
i am a M1 fan too i use it in my Nissan Titan since new (2004) never had an oil consumption issue. But for the Z i leave it to the dealer.
      04-02-2012, 05:40 PM   #7
Alpha_Zulu
Alpha_Zulu's Avatar
I just don't like going 15,000 miles between oil services. I do them in between. That shit is harsh on the engine.
I use extended performance but change it every 5,000 miles.
zpost
