Problems After Updating JB4 Firmware...
03-31-2012, 12:12 PM | #1 |
Guardian of the Night
109
Rep 1,831
Drives: 2010 335i M Sport Coupe
So I updated to the new HEX file today on my JB4... got these codes when I went out for a drive...
2F6C Exhaust fumeflap, input signal <-- I have my cable unplugged, this is unrelated (Golf Tee Mod Version 2) 2ABC Charging pressure sensor, electrical 3100 low boost mode engaged -- CEL displayed 29CE Misfirings, cylinder 2 29CC Misfirings, several cylinders 0000 Failure location not implemented 0000 Failure location not implemented 30FF Boost under target -- possible boost leak Barely made it back to the house. When I updated the firmware it said "Update Compete" so I assumed all was good. After that, I reinstalled the HEX again, and now it is fine. Ran some data logging as well. I'll attach the JPG, and have the CSV as well but can't upload here. Everything seems to be fine now. I cleared the codes out and tomorrow I will run a code check again, unless I need to go back out and drive somewhere again today. Question #2 so I don' have to make a new thread. I can't seem to choose some menu options off the steering wheel. I try to select the gauge sweeping, and when I hit volume up or down, it just goes to the next setting, and doesn't save my selection. The same goes for when I try to use "Disable Radio". The other times I try to choose settings, both needles point directly up, and then closes out the menu. Any thoughts? Thanks!
2010 335i M Sport Coupe -- Black Sapphire Metallic|Coral Red|Loaded|JB4 Stage 3|BMS DCI|VRSF DPs|Camaross 6k AE|Performance Gloss Black Grilles|CF Performance Spoiler|CF Quad Diffuser|Double Layer Black Chrome Quad Tips|CF Roundels|Smoked Reflectors|Red Cyba Scoops|193s Painted Lamborghini Metallic Dark Gray
03-31-2012, 12:37 PM | #2 |
2020 Z4 M40i - 2022 M4C Convt
3129
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
did you input & save the All AFR list & fuel loop like the instructions said?
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
03-31-2012, 12:37 PM | #3 |
Joint Chiefs of Staff
4920
Rep 115,999
Read the misfire code sticky on this forum. If you need addl help on that you can email BMS but it has nothing to do with your firmware update.
If you need addl help on the JB4 controls there is a whole post on BMS' forum with directions. Each menu goes back to 0 regardless of what setting you have saved unless specified in the wheel controls guide as the default display for that menu. If the gauges are centering you are picking options off menu 5 which should only be used to setup the dash for 135 or 335. |
03-31-2012, 01:01 PM | #4 | |
109
Rep 1,831
03-31-2012, 01:02 PM | #5 |
109
Rep 1,831
Not sure what you mean, as I don't see this in any directions I have read off of the N54 tech website. I followed everything word for word as far as I was able to tell.
04-01-2012, 07:55 AM | #6 | |
I even mod my cereal
247
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
It seems as though Terry took off that requirement for the new firmware? I saw it a few days ago when I down loaded the new Interface Software and Firmware, but when I went to upload everything yesterday the red text note was no longer on the instruction sheet. My firmware and Interface Software uploaded fine with no adjustment to the All AFR list and Fuel Loop. What's your take on this?
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
04-01-2012, 08:21 AM | #7 | |
48
Rep 799
Drives: 08 335 silverback
FBO...METH...BIG TWINS
04-01-2012, 08:29 AM | #8 |
3129
Rep 5,264
Did not see he dropped the requirement to load the numbers...will save a bit of time.
Kevin
04-01-2012, 08:47 AM | #9 |
247
Rep 3,441
04-01-2012, 10:12 AM | #10 |
40
Rep 623
I think your getting confused on how to save settings. When you push the volume button and channel button down at the same time you go into the orange light on in screen. The volume control (mph) starts at 0 which is your map settings. Depending on what map you are running you move the channel button up to whatever map you want and then exit the menu meaning press the volume button down all the way. Same goes for the new gauge sweep option. You go into the orange mode, scroll up with the volumer button (mph) to 5 (50 mph) and then move the channel button up to 7 (7000 rpm). Once you have done this press the volume button all the way down and exit the menu to save the setting. It should save with no issues. Make sure you have the car on or in the ACC position which is pushing the start button twice to where you can turn your headlights on. There is probably just one little step your missing so hope these instructions help. You should email Terry if you have any further issues or simply need help finding out how to do something. He has great customer service and responds usually within minutes, not hours. Best customer service I have ever had
04-01-2012, 10:17 AM | #11 | |
109
Rep 1,831
