06-13-2007, 05:43 PM | #1 |
194
Rep 2,486
Aftermarket Brake Pads??
My OEM brake pads are coming to the end of their life. What aftermarket brake pad can I buy for the front and rear.. Thanks.
06-13-2007, 05:47 PM | #2 |
95
Rep 1,269
The brake pads should be covered under the warranty. Even if you want to go with aftermarket pads, have your OEM pads replaced by the dealer first because they'll replace the OEM rotors at the same time too.
2019 Porsche 911 4 GTS
2016 BMW M3 2008 BMW Z4M coupe |
06-13-2007, 07:13 PM | #4 |
95
Rep 1,269
I should clarify that brake pads/rotors are included in maintenance program and not the regular warranty. When BMW replaces worn pads, they're supposed to replace the rotors at the same time, not only the pads. If you're looking for aftermarket pads that generate less brake-dust, most people will recommend you the Axxis Deluxe Plus street pads from zeckhausen.com.
06-13-2007, 08:28 PM | #5 |
My favorite sign.
167
Rep 4,333
Go with Brembo or Stoptech. Can't go wrong with either.
06-13-2007, 10:26 PM | #6 |
8
Rep 191
I will second GP 20....if you change just the pads the Axxis Deluxe are hard to beat. Dave Zeckhausen is THE MAN. Great service and advice with instantaneous turnaound.
06-14-2007, 06:59 AM | #8 |
2422
Rep 11,665
After reading about all the dusting brakes comments,
I orderd a set of Axxis Delux when I first got my car. They're still on the shelf. I really don't find dusting to be an issue at all. FWIW.... If I was doing anything, I'd go with Axxis Ultimate street pads that have higher temp thresholds for better fade resistance at DE track days. (too lazy to swap in track pads) Axxis Delux; 716 °F Axxis Ultimate; 932 °F
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
06-14-2007, 07:03 AM | #9 | |
M = Midlife Crisis
65
Rep 2,006
2006 Z4MC - #LL93158
SS Race Cans, RE X Pipe, DKF Sec 1, Fabspeed Headers, OE STB, AS Shifter, Dave Z CDV, GC Coil Overs, Stoptech lines, Hawk DTC Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, Poly FCAB & RTAB, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM |
06-14-2007, 08:34 AM | #10 |
11
Rep 155
I just installed some Axxis pads on the front about a month ago, they are excellent. I can drive almost 2 weeks without the wheels getting dirty. Its strange because now my rear wheels get dirty first. Have car in shop today to get rear pads/rotors replaced, will replace with Axxis afterwards
06-14-2007, 05:33 PM | #13 | |
Rep 55
I found out the hard way......had 'em on at a DE last year and thought I'd warped my rotors!
06 ///M Roadster
"Black Viagra" |
06-14-2007, 07:31 PM | #14 |
8
Rep 332
Yup - if you are thinking about pads that can handle track duty my favorites have been from Carbotech. Their Panther pad can handle street and light track duty although I know folks who are pretty hard on their brakes and have gone to XP-10s.
These are pads designed for being used at temperature - not for the cosmetics of "no dust".
2010 328ix Sports Wagon
06-14-2007, 07:34 PM | #15 | |
26
Rep 403
Even though you bedded them in?
back by popular demand... |
06-14-2007, 08:39 PM | #16 |
Rep 55
Yep....I bedded them in (twice per Zeckhausen's instructions) about a week prior to the event and then put a few hundred miles on them traveling around town and to the track.
I was squintin' at my rotors and a guy in the next garage asked what was wrong. After I told him I thought I had problems with my rotors he asked what pads I was using and then mentioned he had the same experience. I put the stock pads on for the trip home and everything was fine after that. The ultimates didn't spew enough pad material on the rotors to damage them just enough to give me a case of extereme jitters when braking hard (and I mean HARD). The stock pads apparently removed the excess ultimate pad material from the rotors because I never had the problem again. I admit that I was surprised because I had assumed the ultimates would be good for street and track use.
06 ///M Roadster
"Black Viagra" |
06-14-2007, 09:23 PM | #17 |
Woof!!
Rep 111
Sorry, a little Off Topic
Hey Alan,
Do you run the DE days with the Portland BMW club at PIR? We now return you to the previously scheduled topic....
2006 Ti Silver Z4 M Coupe
2009 Deep Sea Blue 535i xDrive Sports Wagon |
06-14-2007, 09:33 PM | #18 |
8
Rep 332
Nope - Axis Ultimates are not meant for actual track use. StopTech used to hand those out as standard pads when you bought their BBK years ago. I got a set along with a BBK for a 2001 Audi S4 that was seeing a lot of track duty and they didn't do well at all. I spent plenty of time on the phone with the StopTech folks (Matt Weiss in particular) and they were pretty blunt about letting me know that the Ultimates were not even on the ballpark for honest high temperature work. My rotors required serious some rehab work in order to get rid of the deposits the Ultimates left while they went into meltdown mode out on the track.
Any pad that says it is Street/Track use is a compromise pad that is not going to stand up to a heavy brake foot at the track. Folks pushing the straight speeds that the ///Ms can reach are going to be very hard pressed to find an all purpose pad that can handle the loads. Getting a pad that can handle the heat cycles and leave no brake dust (or lots of squealing) sounds like Mission Impossible(TM).
06-14-2007, 11:21 PM | #19 |
Rep 55
AlanL I agree (wish I'd known that then).
Even better.......this occurred while I had the 04 3.0i showing that they definately aren't up to heat cycles on a track.
06 ///M Roadster
"Black Viagra" |
06-14-2007, 11:28 PM | #20 |
Rep 55
I want to add that I ordered the pads from Zeckhausen BUT did not have the foresight to ask him about them prior to purchase.
Zeckhausen's service and tech help are still #1 in my book.
06 ///M Roadster
"Black Viagra" |
06-15-2007, 06:04 AM | #21 |
2422
Rep 11,665
Cmick & AlanL Thanks for the info guys.... great stuff.
This is what makes this place so great!!!!
