Anyone with dyno results for COBB stage 1+FMIC?
03-27-2012, 07:19 PM | #1 |
169
Rep 1,247
I have been using this map now for a bit and I like it alot. I am using the stock throttle with it. But just wondering if anyone has had the chance to get on the dyno with the stage 1+FMIC? If so how did you make out?
2009 E92 BMW M3.
03-27-2012, 11:51 PM | #4 |
208
Rep 2,558
Get some DP's already and come play with the big boys.
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife |
03-28-2012, 05:07 AM | #5 |
169
Rep 1,247
Thank you for the graphs, I appreciate it. Does look good at lower rpms but like you said kind of cuts off. If you dont mind keep us informed as to what COBB says about the data logs.
2009 E92 BMW M3.
03-28-2012, 05:11 AM | #6 |
169
Rep 1,247
your right lol. I was throwing the idea around of gettin DPs but I just dont know if I want to deal with the emissions issues and all. Its kind of a pain here in PA. I was going for the VRSF DPs because of their affordability, but just havent been able to pull the trigger. Still deciding if I should get them or not. I also ran into some other car issues which I had to put out some cash to have fixed so money is a little tight right now. But Im thinking DPs would be nice....
2009 E92 BMW M3.
03-28-2012, 06:20 AM | #7 |
124
Rep 1,362
I did two runs tonight and logged them one in third and one in fourth, this is the first time I've used the virtuall dyno and I tried my best to keep the info accuarate here are my results:
Cobb Stage1+ aggressive Stock throttle IJEOS FMIC, Catback, and Intake |
03-28-2012, 02:46 PM | #8 | |
62
Rep 1,476
Like Skim7x said I need to get downpipes now Hopefully COBB will have their downpipes ready soon then I can get the Pro-tune at the same time and see what that gives me |
03-28-2012, 03:44 PM | #9 | |
226
Rep 2,387
Hope to hear Cobb chime in on this, they had promised their own dynos of stage 1 v301 vs stage 1+ v400 when they first released it. edit: at the very least it should look like the two TQ curves spliced together, V400/401 down low and your V301 up high. |
03-31-2012, 10:59 AM | #10 | |
Cookied
Rep 64
Same set up and still iffy about DP's too...Emissions in NY.. If cobb can find a way to set readiness then I'm in. I don't wanna go through the whole bms dp fix...and drive for god knows how many miles and whatever speed (impossible) OR have to keep swapping them every time (I have an xi..they are a bitch to remove). The CP-e ones are in the checkout cart but I'm holding off untill after I get inspected in june We need a better solution!! And I don't know what cobb is talking about but stage 1+fmic v400 feels MUCH faster.... butt dyno approved!
Procede///PWM///Cobb///KWv1///Helix custom 5 style/// BMS DCI/ //Helix fmic///AWE DV's///... simple daily
