      03-27-2012, 12:04 AM   #1
Richard@M-World
Richard@M-World's Avatar
Drives: NASA TTA #92 M3
Thumbs up M-World Presents: KW Clubsport 3-Way for M3/1M
Championship-winning performance for daily drivers
M-World is pleased work in partnership with KW to install and review one of the first available 3-way kits in the world. Based on the championship-winning Competition 3-way, the Clubsport 3-way is a brand new line of coil over with near-stock ride quality on the street and Clubsport level performance on the race track.
What the hell is 3-way?
The Clubsport 2-way provides independent rebound and low-speed compression adjustments. The 3-way adds high-speed compression adjustments.
On the street, the ride is much improved especially in cities with poor road conditions. The ability to significantly tone down the damping curve allows the car to ride very comfortably over large road imperfections such as potholes.
On the track, 3-way offers enhanced stability and platform control over large bumps and curbstones, offering advanced drivers total control of the chassis.
How are adjustments made?
All damping adjustments are made using adjustment wheels. Rebound (18 clicks) is adjusted at the top of the shaft. Low-speed (7 clicks) and high-speed (14 clicks) compression are adjusted on the piggyback reservoir. Each click is clear and distinct. All changes can be easily made on the ground without taking any wheels off.
How is the ride comfort on the street?
We had Clubsport 2-way on the M3 prior to installation so we had an immediate baseline to compare against the 3-way. On the streets, with high-speed compression on softest setting, the car is now able to ride through large road imperfections very smoothly. The damper is able to completely absorb the impact without upsetting the chassis of the car. The ride quality is excellent and not unlike stock suspension.
How is it on the track?
We will be there shortly. Stay tuned.
Authorized AiM Dealer - Solo/Solo DL | SmartyCam HD | www.m-world.us
      03-27-2012, 12:17 AM   #2
DeeboSTI
8
Drives: 1M
Very interested in your feedback on these coilovers & availability of these coilovers in the U.K.
      04-03-2012, 10:41 AM   #3
M3Power79
Belgium
31
Drives: 1M sold - M4 MW DKG ordered
Is this the "normal-regular" KW V3 Clubsport or smth above it?
"... on the smiles-per-mile charts, the 1-series M coupe can't be beat. It is a challenging piece, a triple-X-rated driver's machine for semi-professionals. Its handling balance provides an open invitation to indulge in latent oversteer, and provides an opportunity to separate the men from the boys. It is an absolute hoot on the track and an addictive plaything on your favorite twisty back road. "
      04-03-2012, 10:54 AM   #4
Aussie_in_London
Aussie_in_London's Avatar
United Kingdom
142
Drives: 1M, i3 & track built Astra OPC
V3's and Clubsports are affectively different to begin with, share the same shell but different valving, piston rods, adjustments etc, but clubsports only came in 2way adjustability, until now and the above being the new 3way set up..... feat high and low speed bump adjustments.
      04-03-2012, 01:16 PM   #5
M3Power79
Belgium
31
Wow!!! Thanks, any price range known?
      04-03-2012, 11:48 PM   #6
VO 1M
VO 1M's Avatar
7
Drives: 1M Coupe
looks great! comes with a pricetag though
      04-04-2012, 08:37 AM   #7
Snertz
H O O N
Snertz's Avatar
Drives: ein M!
MSRP of $5649
U WOT M8?
      04-04-2012, 01:21 PM   #8
M3Power79
Belgium
31
Originally Posted by Snertz View Post
MSRP of $5649
WOW
      04-04-2012, 06:54 PM   #9
Die ///M Rakete
Die ///M Rakete's Avatar
Drives: 2016 F80 ZCP 6MT
MSRP of $5649
OUCH!!!!!
God....why do I have to have such expensive taste
      04-28-2012, 03:21 AM   #10
LotusBoy
Drives: BSM 1M, N55, KW's DDC
WOW
Here are 2012 prices for Belgium, for the 1M:
Variant 3= 1961 euros
Clubsport "3"= 2480 euros
DDC= 2846 euros
All of these are fully adjustable, including in ride height. I'll get the DDC, which is adjustable with a 3 position switch. Modes are Comfort, Sport and Track. In my view, the Clubsport is really firm and meant for trackday fans only ...
      04-28-2012, 01:19 PM   #11
eeghie
Kind of a big deal
300
Drives: an 1M not often enough
DDC= 2846 euros
who is your dealer? Is the DDC price including or excluding WLAN / IPOD adjustability. (without should be ~25xx).
Any curves (comparing to stock) anyone?
      04-29-2012, 01:06 PM   #12
LotusBoy
Hi eeghie ! These are official KW Belgium prices including taxes. The price for the DDC is not including the W-LAN module that you can control with your I-pod, I-pad, etc.. (+300)
I'll get mine from:
www.performance-store.com
It's an independent BMW specialist in Nivelles, Belgium, which is a chassis geek and has a lot of experience installing and setting-up KW's .
      05-01-2012, 08:36 AM   #13
Aussie_in_London
United Kingdom
142
DDC= 2846 euros
I agree, I run clubsports in my astra opc and matched with the comp springs they are very much trackday focused, I wouldn't appreciate in a daily driver but then my opc is semi stripped and has little or no creature comforts so the CS's are spot on as the opc's main focus is track, as for my 1M, it's a general use tool that it will only ever see the yearly pilgrimage or 2 to the nurburgring so the DDC set up will suit very nicely and goes in next Monday for instalation incl the w-lan module.
      05-02-2012, 01:46 AM   #14
Richard@M-World
Based on my experience, ride comfort is not just a function of spring rates, but also the damping curve. I've driven my E92 M3 without rear shocks (it has KW Competition with 1,000 pound/inch rear springs), and the rear axle was surprizingly smooth over large road imperfections.
The beauty of the Clubsport 3-way is that it allows the user to tune down the high speed damping circuit, and this will make a big difference in ride comfort/compliance.
For those in Texas, this weekend we will have an M3 with Clubsport 3-way at Houston M Club's open track event.
Search this Thread:
Advanced Search
