Got my car back from alignment.....and it drives like sh*t
06-12-2007, 09:13 PM | #1 |
hmmmmmmmm
17
Rep 570
So here's the whole story and I'll bold the important parts.
When I first bought my car last July, which came with ZSP and active steering, I noticed the car would seem to skid on road bumps and the steering would seem floaty. I did a bit of searching and it seems like I was experiencing tramlining and the RFT effect. So, fine whatever, seems like a common problem and I'll just deal with it. So November came along and it was time to change into the winter shoes. So I changed my 162's rubber into winter and to my surprise the tramlining was gone and the steering felt brilliant. Just a few weeks ago I received my new summer wheels (VM 19" CSL w/ General Exclaim). I got the new wheels installed including a set of H&R springs last week. I didn't get an alignment done because the garage I went to don't do alignments on cars with active steering. So I drove about a week without getting an alignment done and the ride quality wasn't bad. It felt like driving with the winters on, but lighter. I had my alignment done today at my BMW dealership and for some reason the car drives horribly. I'm experiencing tramlining again, but it's not the RFT fault this time, since I got none. The car was felt fine before the alignment and now the car just feels dangerous. I'm not really sure what I should do right now. I'm pissed and disappointed at the same time. All I know is that the psi level for all four wheels is at 38 and the SA at the dealer told me they had a really hard time aligning the car. |
06-12-2007, 09:24 PM | #2 |
pull my finger to get your kinder® surprise
148
Rep 10,455
Tissot, get an alignment done at Woodbridge Alignment. They're really good, seriously.
4817 Hwy 7 Woodbridge, ON L4L 1S6 Tel: 905-851-3500 http://www.woodbridge.servpro.ca/tes...%20Repairs
06-12-2007, 09:46 PM | #3 | |
hmmmmmmmm
17
Rep 570
OK, I'm planning to go back to the dealer tomorrow. Would I need to pay extra for them to re-align or is there some kind of warranty? Should I just show up or call before hand? I'm no alignment expert, but could the alignment be calibrated back to the specs before the first alignment?
06-12-2007, 09:52 PM | #5 | |
148
Rep 10,455
For sure they'll re-align it for you for free, since they did the alignment and it was not satisfactory. However, seeing that they didn't do it right the first time, I doubt they're going to make it right the second time, but fingers crossed, they will.
You need to book an appointment, it takes a good while to do an alignment. in the future, when you swap out your rims/tires, go to Woodbridge alignment, I had mine done there, top notch guys. They will align your car, go for a drive with you, and realign if necessary. Quote:
06-12-2007, 10:13 PM | #6 | ||
hmmmmmmmm
17
Rep 570
Thanks for all the help. Last edited by tissot; 06-12-2007 at 10:54 PM.. |
06-13-2007, 10:19 AM | #8 | |
7
Rep 30
Tramlining is not a problem only with RFT's, it is a problem with many (all?) high performance tires. I have the same experience with my A4, the tramlining stops when I put the winter tires on and starts when I put the summer tires back on. I'm not saying there isn't something wrong with the alignment, but don't expect that just because you aren't using RFT's anymore that you won't have tramlining. Regarding the ride, 38 is a pretty high tire pressure for everyday driving, and will make the ride harder. |
06-13-2007, 11:45 AM | #9 |
Now With 33% MORE Sarcasm Free!
157
Rep 3,462
Big 19" Wheels and lowering your car will just make tramlining that much worse.
Learning to ride the ridges may help, but really it' most likely not anything you can fix. Although you could find alternative twisty routes to where you're going. There are a couple of highways out here that will really pull you around on the road. Not much you can do but deal with it.
A BMW is Just a Car, it doesn't make you smart, handsome, clever, better, cool, or wealthy. |
06-13-2007, 01:54 PM | #10 |
AC
95
Rep 2,387
Which dealer did you go to get the wheel alignment performed?
My BMW technician tells me the only place they have a "real" wheel alignment equipment is at Parkview (currently). Any other dealership you go to, including downtown BMW, will not have the "correct" wheel alignment equipment.
Your Supreme Leader
06-13-2007, 05:45 PM | #11 | |
119
Rep 2,909
06-13-2007, 07:34 PM | #12 | ||
hmmmmmmmm
17
Rep 570
06-13-2007, 07:37 PM | #13 | |
148
Rep 10,455
achien, your BMW tech doesn't happen to work at Parkview, does he?
06-13-2007, 09:12 PM | #14 |
Smiling politely
165
Rep 7,931
A little OT, but I forgot how bad the tramlining was until I put my 18" 162s back on the car. With the 17" winter tires (and they were RFT, too), I didn't have to fight the car nearly as much. My alignment's fine, it just seems the bigger the tires, the worse the tramlining.
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
06-14-2007, 12:04 PM | #15 | |
AC
95
Rep 2,387
Anyway, he told me this morning Downtown BMW has the wheel alignment equipment also, but it all depends on how much effort the technician put in. He may have to "tweak" the alignment a couple of times before they get it "right". It's very difficult to get it right the first time as every vehicle is a "tat" different.
Your Supreme Leader
